Question about Audiovox VM9512 Car DVD Player
Ipod will not play properly after connected to Vm9512
After detaching ipod, the ipod screen goes black and will not come back on. i reset ipod, it comes on for about 30 sec but will not respond to any menu controls. it shuts back down and will not come back on. I have not had any problems with my ipod until after connecting to the VM9512
Well, the screen issue you are describing with the ipod sounds like the ipod's clickwheel is malfunctioning. A malfunctioning clickwheel will allow you to reset the ipod, but not actually make selections. At this point, you can either replace the clickwheel or if your ipod is under warranty, take it in for service.
*I am assuming that you are actually resetting the ipod correctly. For example, when reset, after bootup, the ipod will ask you to select a language. If you are not getting to that screen when you "reset" it, then you are likely doing it incorrectly. If that is the case, I'd suggest checking your HOLD button before suspecting a bad clickwheel. Since there are slightly different procedures for resetting ipods depending on model and generation, I'd suggest doing a search online (or going to Apple's website) for instructions on how to reset your particular model. Note that ipod generation can be easily found printed on the back case of the ipod.
Posted on Mar 12, 2009
Instruction manual
Which model ipod ??
In keeping with Apple's goal to make user-friendly, streamlined products, the designers of the iPod built in easy-to-use reset functions into each iPod model.
Resetting the iPod is similar to rebooting a computer as all songs and data stored on the device stay there, and only temporary information (such as which song is playing) gets reset.
Follow these steps to reset an iPod.
Toggle the "Hold" switch to the "On" position, then "Off."
The "Hold" switch is the small sliding switch on the top of the iPod.
Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle.
Hold the "Menu" and "Center" buttons.
Press the 2 buttons at the same time for between 8 and 10 seconds.
Your screen will go blank and then boot up with a dark Apple icon.
The icon eventually turns bright and brings you back to your main menu once the reset is complete.
Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process.
Scroll Wheel and Touch Wheel iPods
Move the "Hold" switch from "On" to "Off."
Press the "Play/Pause" button and the "Menu" button at the same time.
Press both buttons together for approximately 6 to 8 seconds.
This initiates the self-running reset process.
Make sure the reset was successful.
If problems persist you may need to perform the reset process once again.
iPod Nano
Move the on-off switch to the "Off" position that shows the green strip.
Leave the iPod Nano in this position for 5 seconds.
Move the switch back to the "On" position.
Use your iPod Nano to make sure the reset worked properly and all your music is intact.
Aug 06, 2013 | Starlite Nextplay Fashion iPod Docking...
How to shutoff ipod a1236
Turn off your iPod by holding down the "Play/Pause" button for two or three seconds. The screen should go blank, and your iPod will remain off until you turn it back on again by holding down the "Play/Pause" button.2 Let your iPod go to sleep. When an iPod isn't used for two or three minutes, it automatically goes into "sleep" mode. The screen will go black until you touch any of the controls. Sleep mode uses considerably less battery power.
  • Oct 11, 2011 | Apple iPod nano
    White Screen Of Death
    MY IPOD IS IS HAS A WHITE SCREEN
    Feb 08, 2010 | Apple iPod nano
    80g ipod video. screen has ipod logo and screen
    hold the select and menu buttons until the apple logo shows up, then quickly switch to holding the select and play buttons, this should put it into "disk mode." plug into itunes and click restore.
    Nov 16, 2009 | Apple iPod MA446LL/A MP3 Player
    IPod Touch Automatically Reverts to Main Menu Screen
    you need to restore your ipod touch by connecting it to your computer and clicking restore. make sure you have backed up your ipod touch before you do this or you will lose everything on your ipod touch.
    Jun 16, 2009 | Apple iPod touch
    My ipod nano third generation is frozen
    You should not plug the ipod to pc while it is playing because it is switches from the playing mode to sync and charging mode you can not play and use the ipod while it is connected with the software without ejecting it from itunes. Do a reset by pressing and holding the center and menu buttons at the same time until the screen goes back and apple logo pops up. This should reset your ipod and fix the problem.
    Feb 20, 2009 | Apple iPod nano
    Frozen screen
    First, make sure the lock slider is in the proper position.  I know, obvious, but you'd be surprised how often this happens.
    Next, slide the lock slider to locked and then back.  Then press and hold the Menu and Select (center) button for 6-8 seconds.  Try a couple times if it doesn't work the first time.  The ipod should reset and work.
    If that didn't work, you can reset your ipod.  But first, try connecting the ipod to your computer and see if it goes into sync mode. If so, wait for iTunes to load and then eject your ipod in iTunes and see if it works again.
    To reset your ipod, slide the lock slider to locked and then back.  Next hold the Play/Pause Button and the Menu button for 6-8 seconds.  You may have to try this a couple times.  The ipod should reset.
    The last thing to do is to let your ipod discharge completely by leaving it at the frozen screen.  Once your ipod is out of battery, reconnect it to you computer or a power adapter and let it charge.  Then try to access it again or repeat the steps above.
    Nick
    Jan 22, 2009 | Apple iPod nano
    Ipod
    Whatever you do, do not disconnect it when it is like that. Do a reset (hold the menu and play buttons until the screen goes black and then quickly disconnect it from the computer.
    what you do now depends on what the iPod does after you disconnect if from the computer. If the screen comes on, then you are OK. If it comes back to the do not disconnect screen, do a reset again, and this time when the screen goes black, quickly hold down the play/pause key and the middle key. Hold them until you see a check mark and the words, 'disk mode'. Connect it to your computer while it is like this and restore it. Hope that helps.
    Sep 07, 2008 | Apple iPod MA446LL/A MP3 Player
    I cant see video from ipod
    No in the ipod settings have u turned on the NSTF signal for the TV?
    May 25, 2008 | Audiovox VM9512 Car DVD Player
    4ht generation 40 gig ipod will not sync but shows as a drive in windows
    hold the center button and the menu button until the screen goes black. then hold center and play until the screen goes white and says "OK to disconnect". The ipod has now been forced into disk mode and should now sync. Once you have it connected to itunes, try restoring the ipod to fix the problem forever. If the ipod still will not sync in disk mode, try some of the USB tests in diagnostic mode (info here)
    Nov 21, 2007 | Apple iPod MA446LL/A MP3 Player
    Audiovox VM9512 Car DVD Player Logo
    165 people viewed this question
    Top Audiovox Car Audio & Video Experts
    xxxxxx xxx
    Jaime Hernandez
    Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
