Question about RCA D61W20 61" Rear Projection Television
RCA D61W20 Projection TV
Can you email me Thomas31093@aol.com Having issues with TV. Live in Georgia and shops here give you the run around I would like a straight answer to my problem. Thanks for any help.
  • 1 more comment
  • thomas31093 Jan 07, 2009
    I had sent you a message earlier on it. I see you have posted answers on here and it really sounds like you know what the real problems with this model. It takes repeated attempts to turn it on. When I hold the power button down it will flash a code 19 one blink a pause then nine blinks. It works great once its on.
    Is the deflection board the board in front of the board where the power cord enters the back of the TV? There is a tray with 4 boards on it. The deflection board the one with the three capacitors on it? Thanks for your help. Like I said before when the TV is on it works great, just getting it on takes a few tries.
  • ladywinn
    ladywinn May 11, 2010
    What seems to be wrong with your TV? I will try to help as much as i can.
  • RCA Master
  • 5,138 Answers
On the Deflection Board CK 3 capacitors cp150 2200uf 16v cp114 cp120 220uf 35v If cp 150 is puffed up top then it is bad so replace all 3 capacitors. Resolder all pinns on FBT too. and make sure second ribbon connector is in good.
Posted on Jan 07, 2009
Testimonial: "Bad capacitor, an easy fix. When removing bad capacitor that was puffed up on top, turns out it wasn't soldered in well from the factory. TV works! A+"
  • ladywinn
    ladywinn Jan 08, 2009
    2 boards on bottom first board to left Deflection next to it SSB has turners on it board behind SSB is AC board two boards up top regulator on left /right is convergence control board. Deflection board has FBT flyback Transfomer it has 2 wires coming from it RED /Black This supplys high voltage to circuits.
Manual rca D61w20
Hello
Get into this site. You can download the user manual for your RCA D61W20 HDTV from here for absolutely free. It is in PDF format. If you feel any difficulty in downloading the same, send your Email ID to me by Fixya. I've the downloaded manual for your TV, and I'll send a copy of it to you by return mail. OK>
Oct 14, 2011 | RCA D61W20 61" Rear Projection Television
The Tv we have is the RCA D61W20 and it wont do anything it will not power on. What should we do?
Its most likely the failed capacitors CP150, CP120 and CP114. You can get the repair kit with that same name at www.tvrepairworld.com the kit also contains the CD with repair instructions.
Jan 07, 2010 | RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
Tv repair
usuallt that model can have issues with the flyback going out without warning. Go to this link and leave them an email indicating your model number and symptom they will be able to help you out they have alot of experience with RCA products
http://servicemanuals.vstore.ca/
May 07, 2008 | RCA D61W20 61" Rear Projection Television
Tv D61W20
so basically your power supply is out?
Nov 27, 2007 | RCA D61W20 61" Rear Projection Television
RCA projection televeion problem.
take your tv to a tech for repairs the tv power supply or related circuit is defected.good luck
May 14, 2007 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
