Question about HP Photosmart 7450 InkJet Printer
Helpp A week ago I was printing a picture. The paper jammed so I took it out and tried to print it again. When I tried to print it again, the printer did nothing and when I checked it was because it was turned off. When I pushed the power button it didnt turn on. I have checked all the plugs and it still doesnt work.
  • Anonymous Mar 05, 2008
    #28 with chech mark
Are you sure that all the paper came out? I don't really know anything specific about your partic- ular printer; but if any paper is still in the paper path, it may not allow itself to power on. Can you see that the paper path is clear all the way through from pickup to finish? Do you have a user's manual with the printer? You may be able to perform some sequence of steps to clear the nvram on the printer if necesary. If still no power, investigate power connection, try alternate source (other outlet, power strip). Also, alternate power cord for printer if possible. Good-luck:)
Posted on May 28, 2007
I bought the printer a couple of weeks ago and have only printed a maximum of 20 pages. Now when I try to print, the "error" light keeps coming on but I've looked and it doesn't say what the...
Try opening the printer and checking for a paper jam.
It's also worth removing the toner cartridge and placing it back again, therefore forcing the printer to go through the diagnostic cycle again. Sometimes that solves the issue.
Hope that helps!
Mar 14, 2011 | Brother HL 2140 Laser Printer
My printer got jammed with the paper. i took the paper out and clicked print again. the printer is still not printing. i restarted my computer but it still doesn't work. what do i do??
Power off your printers and remove the cartidge and power on.the printer will re-alligned itself and check if it work.If even some small piece of paper is stuck inside the printer roller,it will still give you paper jam message.If that is the case try to print test print from the printer itself.
Dec 22, 2009 | HP LaserJet 1000 Printer
Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
Recurring false paperjam alert
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | HP LaserJet 4100dtn Printer
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Dell printing problems
Try fanning the paper and see if that works.
Jun 30, 2008 | Dell 926 All-In-One InkJet Printer
Paper jam error message
Try this website for a paper jam problem with your printer.
Click Here
May 26, 2008 | Lexmark P4350 All-In-One InkJet Printer
Prints a couple of pages - then jams
Well, for now it seems to be fixed - I opened up the paper tray and there is a little part that grabs the paper on the front of the tray - kinda sticky - I just took a paper cutter and put a couple of scratches on it and it is grabbing the paper for now. I do have some of those to use for replacements - but I had just changed it about a month ago and don't think it needed to be changed out again - they usually last quite a while. So, we'll see how long this lasts. We do a lot of printing on this thing and it has been a great printer - maybe we are just wearing it out!
May 20, 2008 | Ricoh CL4000DN Laser Printer
"Paper Jammed"
Yes I have the same problem :-( I have lots of work to do!!
Apr 13, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Printing
Placing one sheet at atime is worse usually as these units feed off a minimum level. Keep them topped up to at least no less than 10 sheets. The printers sound like the have a paper feeding issue. Could be a jam. Open unit, check for paper jam. Cheers lilacgerry xxx
Sep 13, 2007 | Canon PIXMA MP180 All-In-One InkJet...
HP Photosmart 7450 InkJet Printer Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
