Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
GARAGE DOOR OPENS BUT WILL NOT CLOSE AUTOMATICALLY
GARAGE DOOR OPENS AUTOMATICALLY BUT TO CLOSE, WALL UNIT BUTTON MUST BE HELD DOWN UNTIL DOOR TOUCHES FLOOR, OTHERWISE DOOR WILL MOVE DOWN ABOUT 6 TO 12 INCHES AND THEN REVERSE ITSELF. THIS IS ALSO THE CASE WITH THE DOOR DISCONNECTED FROM THE SLIDER ON THE RAIL. SENSORS ARE ALIGNED AND GREEN LIGHT IS ON. SENSORS REACT PROPERLY WHEN BEAM IS BROKEN. NO OBSTRUCTIONS FOUND ON RAIL OR DOOR TRACKS. OPENER IS CRAFTSMAN 1/2 HP CHAIN DRIVE. MODEL # 139.53975SRT1
  • 1 more comment
  • f_stella Jan 15, 2009
    Yes, bulb on motor is flashing 10 times. I have looked closely at sensors and one has sustained some external damage, so I will try replacing it and follow up on results. Thank You !!!!
  • Anonymous Jan 16, 2009
    I have this problem however the sensors are working green light is on. Any suggestions
  • f_stella Feb 12, 2009
    Sorry for the delay in responding to all the helpful suggestions. Because of the bulb flashing 10 times, I replaced both sensors(even though the green light was working properly) and it did fix the problem. Thank You to all for the help. I really appreciate it !!!
    Champion:
  • 244 Answers
Is bulb on motor flashing 10 times. then you have electric eye problem. otherwise, sounds like you need to increase down force a hair. adjustement is on logic board, right knob.
Posted on Jan 15, 2009
Ihad the same problem, and fixed. it is very likely the infrared eye that is a safety protection.either the wire is loose or something is blocking one of the electric eyes located on either side of the garage door near floor (on each side)
Posted on Jan 17, 2009
My garage door opener opens with wall button but button must be held down until door touches floor to close. This unit is a liftmaster HBW0777 Model K1027 & does not have a sensor system
I think the issue is a missing sensor safety system. Try jumping a wire between terminals two and three. Then the wall button should work on a single short push.
Nov 15, 2016 | Building Materials
How do I fix my garage door opener? May have moved sensors. Door will not open or close. Tried to align the sensors but don't know if they are aligned or not. When I push the wall button I hear 2 clic
on mine i have one red one green just the same keep trying to adjust the blinker or both till it is solid color check wires on back of it also.
Jan 17, 2015 | Building Materials
I have a Sears craftsman model 139.53637SRT garage door opener. My remote has not worked in a long time. I use the wall control button and have to hold the button in order to open or close the garage door....
It sounds like your door sensors may be bad or misaligned. Make sure the small light on each sensor is lit and not flickering. That could be the cause of your having to hold the wall button down until the door is closed. You can buy a universal remote but if you only had one remote before it could be the receiver that has quit. A new remote would not fix that but the only way to find out is to try.
Aug 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener opens with remote but will not close with remote. will open with wall button but button must be held down until door touches floor to close
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall opener blinks but will open & close door.
Press and hold for 3 seconds the lock button on the wall control.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Must hold wall unit to close garage door...
there is an error in the system. most likely The safety beams (mounted on the track near the floor) are out of alignment and the LED light should be blinking. The garage door opener will not let the door close if the beams are misaligned. Realign them and the LEDs on the beam or on the operator will stay on. you should be able close the door now with one push.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,034 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
