Question about AudioBahn DUB Mag Audio DUB2502 Car Audio Amplifier
Amp stuck in protection mode, help!!
My entire system was installed by a person @ tweeter... got 2 12" mtx's, a zx750 kicker amp, pioneer deck... my amp usually functions very well.. recently it has been cutting out my subs and flickering on an off from green to red (protection) ... could the amp be drowning my subs? ... subs are running 900 rms .. amp is 750 wattage.. only had this problem once in the past, but now it is occurring more often... idk what to do
  • krice345 Jan 07, 2009
    MTX Thunder's 5500, both in the same box.. here's a link
    http://www.mtx.com/caraudio/products/sub...
    also... when i turn on the battery of my car, the amp stays in protection... but when i turn on my engine, the amp switches to the green light... but won't power my subs still...
    Scholar:
  • 96 Answers
For 1 the amp is no where close to strong enough for the subs and 2 if the amp is mounted on the box it is vibrating the electronics loose. you always want the amps rms power to be be about 25% more than the speakers rms rating, from the sound of it you are either undriving the amp (clipping) or running the amp at 1 ohm load which is making it burn up. if the amp gets hot (which class d amps should never ever do) then try running just 1 sub. if the problem goes away then you know the amp is not enough for the subs. try a hifonics amp you will be amazed at the quality and power difference. I sell all major brands cheaper than almost anywhere. let me know the exact model of the subs and i can recommend a better amp for you.
Posted on Jan 07, 2009
  • wyatt connolly
    wyatt connolly Jan 08, 2009
    sounds like the output board is bad, not worth fixing it if thats what it is. I used to sell fosgate but i only do it on special order now because they have had so many similar problems.
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Only one of four speakers puts out sound!
Check all your RCA"smake sure they all have output..Then use a fluke metere, or any meter you can get that tests ohms, and measure each speaker..they should all read arround 4. If the outputs from the deck are good, and the speakers measure correctly, then you have got yourself a bad amp.
Jul 29, 2009 | Kicker (ZX350.4) Car Audio Amplifier
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
Kicker L712 and rockford fosgate800a2 amp.weak prfmce
Is the box sealed air tight, leaking around speaker? plumbers putty works great. Amp may be good enough for the mtx but underpowered for the kicker. When kicker says 1000 watts that what it is (at a 14.4 volt input). Mtx is ok but may not tell the true watts. Check to see if the speakers are the same ohms also!
Jan 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker amp
if you amp is in the PROTECTION MODE its means that there some defective part , like for example the main ICs or TRANSISTORS output might be defective , and thats why its on the PROTECTION MODE , needs to be taken to a expert technician for repair.
Apr 16, 2008 | Kicker DX350 Car Audio Amplifier
Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Dec 28, 2006 | Kicker (ZX750.1) Car Audio Amplifier
Car Audio & Video Logo
379 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
