Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 plug in clip on the bottom of Screen fell off
Is it normal for the bottom plug connection to pop off?
I don't believe I broke it as I originally thought. the bottom plug fell off as I was removing the garmin from the windshield. I did not pull it by the plug. sometimes it would come off the window in such a way that I caught it by the wire. Maybe this is how it poped off.
I noticed a short copper fitting and a long copper fitting. I assume this is the positive and negative connection. I though one was broken since it was shorter than the other. I tried to put back, however I have had not luck. what should I do
Thanks Bob
Not fixed yet, don't want to buy the answer, I will call Garmin
Thanks
Bob
Posted on Jan 07, 2009
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot C340 is not allowing me to enter an address - when it prompts for state it's blank and won't allow me to type my state, so is my food screen, lodging and fuel won't come up. Yet it...
There is a small pinhole on the bottom or right hand side of the unit for reset. Try hitting this with a paper clip or pin. If that doesn't help you may have to take it into a store.
Apr 14, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin GPS not switching on
If the reset described by justaskjoe doesn't help, then check the power cord. There's a fuse inside the power plug, held in by a screw ring which is notorious for coming loose. Make sure the fuse and spring are in place and the ring is screwed on firmly. My daughter's C340 stopped working because that ring came loose and the fuse fell out. Also remove the unit from its mounting cradle and snap it back in to ensure good contact.
Oct 10, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
GARMIN C340 VOLUME CONTROL
I had the same issue. My C340 fell of the dash and the volume control (potentiometer) broke off and was rattling inside the case. I tried to find a replacement (103B stamped on the pot) but have not been able to find one. I tried a mini 10K ohm pot from Radio Shack, but the posts were not properly positioned for the circuit board inside the Garmin.
I took the easy way (for now) and simply strapped the two control points together with a piece of wire giving me maximum volume. Orient the circuit board with the missing volume control to at the bottom right. The control mounts with 5 points, two on the right edge of the board are simply physical mounts. There are three other connection points just to the left in a slight arc. The top and bottom point have holes to place the legs of the pot. The broken off legs may still be in these holes. Solder a piece of wire between the top and bottom points. Be careful since the solder pads (to the left of the holes are very delicate.
Not an elegant filx, but you get the voice back.
Jim H
Sep 03, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Screen frozen
Be aware - A Master Reset WILL ERASE ALL OF YOUR FAVORITES. To do this, turn the unit off. Press and hold the bottom right side of the screen and turn the unit on.Keep pressing the screen until the unit asks if you want to reset. Press yes. This will do the Master Reset.
Mar 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
C340
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
