Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
CAN I USE AN ACTIONTEC G704WG IN THE FOLLOWING CONFIGURATION: 1. CONNECT THE G704WG TO MY PC, ETHERNET TO ETHERNET 2. COMMUNICATE WITH MY NEARBY HP LAPTOP WIERELESSLY, BACK AND FORTH. THANKS, WAYNE PHILLIPS
  • Anonymous Apr 07, 2009
    i need help to connect actiontec to my att dsl acct
  • 104 Answers
Yes that is possible connect your PC to the actiontec using the lan cable. set your wireless network, then have you other hp join the network.
you can share folders, and printers, and also have your HP connect to the internet through that actiontec.
Posted on Mar 24, 2009
The dsl modem the i have did not come with an access code .. how do i find it
This Utility program from HP will help you locate few details on your network
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Nov 06, 2010 | Arris Netopia 2210 ADSL2+ Modem SinglePort...
Tip
Setting up a Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network. Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/ IP) address automatically, so your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each other across a network, such as the Internet.
First, find out which Windows operating system your computer is running.
You can find out by clicking the Start button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router. The next few pages tell you, step by step, how to configure your network settings based on the type of Windows operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/ IP line for the applicable Ethernet adapter. Do not choose a TCP/ IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/ IP appears by itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files. Check for the files at c:windowsoptionscabs, or insert your Windows CD-ROM into your CD-ROM drive and check the correct file location, e.g., D:win98, D:win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dial-up Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/ IP) is checked. Highlight Internet Protocol (TCP/ IP), and click the Properties button.
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the Classic interface (where the icons and menus look like previous Windows versions), please follow the instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon. Then click the Network Connections icon.
If you would like more information on setting up your connection, please post your questions and I will surely respond.
Also for any clarification, you can email me at titilayosodipe@live.com
Best regards.
Sholly-NG
on Jan 07, 2010 | Computers & Internet
Tip
Setting up a Router
in product damage.
Overview
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
If you would like more information on setting up your connection, please ask me a question.....
Cheers.
on Jan 03, 2010 | Computers & Internet
D-link G524-T router; this works fine with a
If you get the same speed on all three computers, I'd recommend replacing the router. I can't imagine any possible configuration setting that would cause a router to communicate at only 10KB over a wired Ethernet channel.
Nov 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Cant get my notebook to connect wirelessly to the router/net
It does sound like you may need to upgrade firmware. Not sure what OSyou are running?
You might like to try:
1. Disable Windows Firewall
2.In Internet Options Control Panel go to the connection tab and then theLAN Settings where you can uncheck the "Automatically detect settings"button.
3. If you have any third party software, I would get ridof this and ensure that the"Windows Zero Configuration" in the Servicesmenu is set to "Automatic" and the status is started.
Interestingly,Anti Virus programs sometimes interfere with wireless set up - youcould see if it helps by disabling it whilst configuring your wireless.It might also be worth trying to connect without any encryption code& see if that will connect - you can then sort out the encryption.
You might find this site of some use
http://www.vista4beginners.com/How-to-setup-a-wireless-connection
Mar 13, 2009 | Actiontec Electronics (GT724WGR) Retail...
2 linksys200 ? configurer sur le meme reseau
in product damage.
Overview
the Router.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
Connections icon.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 23, 2008 | Linksys Computers & Internet
Linking wrt54g with actiontec m1424wr
You need to check the ip address of your actiontec router, the default ip address of linksys router is 192.168.1.1, they should not be the same or else you will not able to connect the router to the internet.
To access the router web configuration
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3676&p_sid=fvzPHEYi&p_lva=3687#
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740145678B574
Let me also give you the site on how to add the linksys router to another existing router.
The linksys has 4 LAN port and 1 "Internet" port on the back - we ONLY use the LAN ports NEVER the Internet port - because your existing router is connected to the Internet - your linksys is connected to the LAN
http://www.kriyayoga.com/love_blog/post.php/368
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Linksis wireless computer setup for WRT54G model
in product damage.
Overview
the Router.
Connections icon.
Dec 28, 2007 | Linksys Wireless-G WRT54G Router
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
240 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
