SanDisk Sansa m250  MP3 Player
Problem for SanDisk Sansa m250 (2 GB) MP3 Player
Battery problem ???
By liquiddeath on May 27, 2007
my sandisk rhapsody when i plug it into the usb it doesn't say charging it just goes back and forth on the start up screen.
sometimes staying frozen with the rhapsody screen on.eventually it will say power to low and shut down.
Solution #1
posted on Jul 06, 2008
Not Rated)
ThaMp3Doctor
Rank: Guru  SanDisk Expert
Rating: 86%, 4606 votes
Try the firmware upgrade first
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa m250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa m250 MP3 Player
Do you recommend SanDisk Sansa m250 (2 GB) MP3 Player?
Answer
Answer
does the player need to be turned on to add music?
Answer
sansa sandisk m250 can't access recorder. when I push white button on player, fm/am/, recorder it... (More)
Answer
Hi. My computer will not recognize the sansa e250 ipod when i connect it anymore. Can you please... (More)
Answer
I have a Sandisk 2.0 GB MP3 player. It loses it's charge with the battery fully charged after about... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa m250 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 384
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
