Question about Canon PowerShot A75 Digital Camera
I would like to turn off the flash.
What icon on the menu refers to the flash?
  • 10,594 Answers
Electric sign is used as flash sign in digital camera.
Below is an image of that sign...
Posted on Jan 06, 2009
  • 33 Answers
The flash icon is usually a little lightning bolt.
External flash not firing in manual mode
In order to have your "External" flash work on your Rebel XSI, you need to go into the menu and turn on the external flash function. If you dont know how to enter into the menu mode, refer to your operating manual.
Nov 22, 2013 | Canon EOS Rebel XSi Digital Camera
How to turn off ringer at particular extension?
Do Not Disturb (DND)
When DND is enabled, the telephone will not ring when someone calls, but the line
indicator still flashes. In Personal Call Manager, the
You Have a New Call dialog box
still appears and the icon for the call appears in the Calls box.
You can turn the Do Not Disturb (DND) feature on or off from the
Calls menu or the Personal Call Manager icon in the task tray.
Turning DND on or off
To turn DND on or off:
1. Click the Personal Call Manager task tray icon or the
Calls menu.
2. Click the DND menu item.
When DND is on:
• the Personal Call Manager task tray icon changes to
• the symbol check
appears beside the DND menu item on the Calls menu and the
Personal Call Manager task tray menu
• DND appears in Status bar
Oct 23, 2013 | NorStar Meridian M7310 Phone
My flash will just not turn on. I have a casio exilim EX-Z35
At back camera, have lamp flashes orange where to indicate flash is charging and to tell image will not recorded(disable). You will can not take another flash until that lamp is stop flashing orange to indicate charging is full. in other view, please check at lcd screen have appear flash icon.
click button play mode to display menu. change set flash to on if flash icon is not display
for user manual
User manual trobleshoot
May 09, 2011 | Cameras
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
I want to take a picture of an old photograph, how do I stop the flash coming on?
Hi there LisaMarie,
To turn off the Flash, you need to go to Menu, then go to Flash mode.
Select or highlight the icon with the flash with "slash". Exit menu. Flash mode shown by icon at bottom of monitor.
For the illustration on how to do this, you can go to page 24 of this manual.
http://www.nikonusa.com/pdf/manuals/coolpix/4600_5600_en.pdf
Hope this helps. Good luck!
Nov 27, 2009 | Nikon Coolpix 4600 Digital Camera
Hi there, my Nikon D40x flash suddenly stopped working (popping up but not flashing) after I was fooling around with the manual settings, now no matter what I do the "no flash" icon appears beside the...
Try turning camera on,
Then press both Green buttons for a count of 10. This should restore factory reset.
Some models also have a reset button under a connector flap, or go into your menu. Under Custom Setting Menu, choose Menu Reset.
One of these methods should work.
Sep 22, 2009 | Nikon D40x Digital Camera
My sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
go into setup menu and turn on the smile detection. go to photo and press the right arrow should have a pict of flash icon . press until the flash says auto.
Jun 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Flash themes
Hi Guys,
base on how you describe your files and base on what i know about sony ericsson, we can't merely change the menu icons, we need 3rd party software to access the phone and could be risky though if you don't know how to operate it.
If i understand you correctly, those themes your having with .xml file and icon images are for flash menu icons. Unlike Nokia high end phones,where you can just install the themes directly unto your phone via usb cable and the menu icons will also change according to the theme you installed.
But if you want to play around your phone's menu icons, you can google it up " Changing W880i menu icons ", but i won't recommend it. :)
May 02, 2008 | Sony Ericsson Walkman® W880i Cellular...
Flashing icon
Low shutter speed icon means that when you take photo the image will be blurry if camera moved.
Is there this icon when flashlight is turned on?
Feb 13, 2008 | Nikon COOLPIX S6 Digital Camera
How do I turn my flash off on my samsung digimax 4010
You don't say which model Digimax you have. Hopefully this will cover most models.
First, make sure the menu is not being displayed on the LCD monitor, otherwise you'll just move around in the menu screen. You must also be in photo record mode, ready to take a picture (not in playback or movie mode).
There is a button (usually on the left side of the direction pad) that looks like a lightning bolt. I can't remember the exact number of times you must press it, but the display should indicate that the flash is turned off as one of the options as you cycle through them.
Depending on your model, the modes are likely to be Auto Flash (bolt with an "A" icon), Auto with Red-eye reduction ("eye" icon), fill flash - always on ("bolt" icon), Slow sync (bolt with an "S" icon), and flash off (bold with a line through it icon).
Also depending on your model, you may not be able to turn the flash off depending on which recording mode you're in. For instance, you can't turn the flash off if you're in the "Backlight" recording mode.
Dec 13, 2007 | Cameras
Canon PowerShot A75 Digital Camera Logo
144 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
