I just installed a new motherboard and CPU. When I power up the system it is not detecting my HD.
  • 2 more comments
  • fyrefly Jan 07, 2009
    Win XP SP3
    Motherboard: Asus M3A78 Pro
    CPU: Athlon X2 6500
    Memory: 1G DDR2 667
    HDD: Maxtor 160G
    I have tried connecting The HDD by itself, with the floppy, and with the floppy and DVD. I keep getting locked into a loop where I get the "start in Safe Mode" screen. The it acts as though it cannot read the HDD.
    Yes the HDD was used with the last system. I was hoping not to have to back up all the old data as I don't have a spare HDD, looks like my laptop is going to get full. Thank you for the help.
  • MrJeebs May 11, 2010
    The impression that I'm getting is that you had an existing installation of XP, and now you have installed a new mobo and cpu, expecting the XP installation you had to work with the new mobo and cpu?
    Need system specs...
    President:
  • 2,351 Answers
Hi fyrefly, I'm guessing the hdd is connected to, SATA1 port on the MB & the hdd is also listed in the boot menu! (So it should load).
If not check it. Make sure it is. You mentioned above you have Win XP w/SP3 installed. That is very tough to imagine, unless you had the hdd installed on your old board when you updated it to SP3.
If I'm correct you need to do a fresh install of windows on the hdd. Windows can see all the old drivers & hasn't a clue what to do with them. So it sends you to safe mode. I can understand that you do not want to loose your personal data. The best way to not loose your data would be to hook up your old board with the hdd. Add a second SATA or PATA drive to the system & copy & past all your personal data to the SATA or PATA slave drive. Here is a list of what you need to back up.
C:\Documents and Settings\ User name\Application Data\Microsoft\Address Book
C:\Documents and Settings\ User name\Desktop
C:\Documents and Settings\ User name\Favorites
C:\Documents and Settings\ User name\Local Settings\Identities
C:\Documents and Settings\ User name\My Documents
Data from any program you may have installed.
Once the data has been copied to a slave drive you can put it back into the new Asus board. Boot to the windows CD & format the hdd & install windows. It's always recommended to do a fresh install of windows when upgrading to a newer board. There’s only one exception to this rule. That is if the MB your switching to is exactly the same as the old MB. You do not need to put the old mother board back into your case for this data retrieval. Grab a couple of books about 1" to 2" thick & lay em on a table. Take a static bag (Like the one that covered the MB & lay it over the books). Place the old MB on the static bag. Hook up your power supply, video, hdd's, keyboard, mouse & connect your monitor. Use a pen & short the power on pins coming from the MB. The system will boot. Copy & past your data to the slave drive.
(Data saved)! Re-connect your new board (still in the case). Boot to the windows CD, format & install.
Install your programs, printer & update windows. Copy & past your data back to your hdd.
Everything should workout just fine. Windows will be happy too!
I have done this more times than I can recall. Its time-consuming, I know but its worth every minute.
Good luck fyrefly!
If the suggestion doesn't fly, tell me why.
Thank you for using fixya.
Mike
Posted on Jan 07, 2009
Unknown cpu detected asus.Bios update is required to unleash its full power.
You will get this message when you install a CPU that is not supported by the mainboard BIOS. Many older mainboards have sockets that will support much more powerful CPUs than they were originally manufactured for. In some cases, the BIOS may be upgradeable to support the new CPU, in others, the CPU may draw too much power or the mainboard chipsets will not support the CPU capabilities. If your CPU is on the list of compatible CPUs...you may need to upgrade the BIOS to support it. You will need to install a CPU that the mainboard will run with to do the BIOS upgrade prior to installing the new CPU, however.
Jan 03, 2014 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
The cpu doesnot detect the HDD. there is a boot failure.
are the cables in right power cable and the ribbon or sata cable in right?
Nov 28, 2013 | Mitac MSC-242 Motherboard
Ok guys I just did a new build with this system http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=281508&CatId=332 The system works fine from a cold boot. But if I...
You are new into this. Follow the step below to solve this problem.
Remove the FAN of CPU, remove the heatsink sinlk and then remvove the CPU.
Put a "Thermal Paste" on the surface of the CPU. Make sure it covers the CPU then. put the heat sink
back on followed by the fan. Turn on your motherboard and reply if this problem is till avail.
Thermal Paste can be found at RadioShack.
Please rate 4 if this solved your problem.
Apr 25, 2011 | EliteGroup ECS A740GM-M Value Socket...
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
Hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive...
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Aug 15, 2009 | ASUS Computers & Internet
System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
Pc computer slow
By saying " installed new programs " what did you mean ?
Reinstalling XP after you upgraded ?
You might also try a driver update program such as driver detective. Or Manually update all the drivers. I doubt the motherboard is going bad making your pc run slow.
Jan 04, 2009 | Dell Inspiron 6000 Notebook
Asus motherboard cannot detect Seagate SATA drive
Does your internal speaker beeps or stops telling you there is no hd detection?
Try to put another hd.
If you are using Windows reinstall it.
Does the red light blinks
CHECK out the power chord to hd and all power connections from psu
Dec 11, 2008 | ASUS A8N-E Motherboard
I have a 6gb HD with my os anything bigger it wont work??
You need to go to your BIOS and check if your BIOS recognizes your drive. You might need to upgrade your BIOS with the latest firmware. You've been using 6GB drive, so I suspect you have older system and your new drive with higher capacity might not work on your system. Another possibility is you need to run HD installation utility that usually comes with the drive.
Regards,
Feb 27, 2008 | EliteGroup L7VMM2 Motherboard
Computers & Internet Logo
465 people viewed this question
David Payne
David Payne
