Question about Clarion VRX745VD Car DVD Player
What cords do i need to hook up a clarion vrz935vd tv deck
I need to know what cords i need to make my deck work?
  • 3 Answers
YOUR GONNA NEED A WIRE HARNESS THAT MATCHES YOUR VEHICHLE FIRST OF ALL
Posted on Jan 08, 2009
I bought a wiring harness for my honda to hook up my stereo deck and but it wont turn on, are the color codes different or just match the color to color??
If you mean you bought a wiring harness adapter for your car so you could hook up an aftermarket deck - yes it's just color for color then.
Feb 03, 2011 | Clarion Car Audio & Video
What are the 2 yellow wires for on the back of my clarion DB186MP
the large yellow wire is constant. unless you have a changer hooked up to the deck, don't worry about the smaller yellow wire.
Dec 17, 2010 | Clarion DXZ835MP RB AM/FM/CD/MP3/WMA...
Need to know how to hook up the dinosaur nintendo
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2010 | Nintendo NES Console
I cannot match up the wires from my clarion DB265MP head to the wires from my 99 honda accord lx. when i ground the head and touch the main power line to the battery terminal, it works though. what gives?
you need to buy the wiring harness that is for your car then you can just hook the harness to your deck and plug it in to the car,unless your wires in your dash are all cut up,in that case you need a tester light.ground the light on somthing and look for the wire that lights up when the car is turned off,this is your battery back-up it goes to yellow on the deck,next look for a wire that has power with your ihgnition and loses power when ignition is off,this one goes to the red on the deck,look for a ground they are usually black but test it for power cause that would blow your fuse,or make your own by drilling a hole somewhere in the chassis and attach to black wire on deck,as for speakers you will prob need to remove front speakers,look at the colors and these are the same as colors youll see where deck is,then check back speaker wire colorwhich also runs to your dash
Jan 06, 2010 | Clarion DB265MP CD Player
What do i need to hook up a clariondrx9375r1 to a 2000 ford f150
You will need an amplifier. That deck has no built in amp.
May 02, 2009 | Clarion DRX9375R
My clarion vrx935vD doesn't come out.
simple thats because you must have forgot to plug the small adapter in the back of the deck that has a yellow and black wire coming from it. if you have then one of those two wires are not hooked up to the right place. and if that fails then either u have a bad connection somewhere in ur car wire or in the inside of ur deck. i had the same problem when i hooked up mine i just forgot to hook up that adapter because its really small
Oct 06, 2008 | Clarion VRX935VD Car DVD Player
Clarion eqs746
more info would be nice...
what did you hook it up to?
Mar 23, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Clarion VRX935VD
I have had a 935VD(Clarion) for about 6 months now, and i decided to add headrest monitors. After i did the physical installation, i moved onto the wiring (obviously). The way i decided to hook the power up was to tap into the accessory power feeding the brain of my 935VD - that may have been a bad idea, but whatever, i did it. Anyway, when i was installing it i accidently grounded the accessory wire and blew the accessory fuse under the hood. Thats fine, i just finished wiring it up and replaced the fuse after completion. The problem is that when i turn the car on now, the deck will not go on. On the deck - in its closed position - all the buttons light up, but the front display does not go on, and it acts like it is off (the eject button works but it will not take a CD in). I was wondering if you guys have any suggestions. I would apprecaite it. Right now im nervous that i fried the brain, but i where it was grounded was between the battery and the brain, so it should not have done n e thing to it... who knows...
Jan 08, 2008 | Clarion VRX935VD Car DVD Player
Clarion Problems
take the deck back to where u boiught it from its faulty
Nov 04, 2007 | Clarion DXZ475MP CD Player
Clarion VRX745VD Car DVD Player Logo
163 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
