Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak ESP-3 printer won't print black
Every time I try to print a document the black ink does not work. I even put a new black ink cartridge in. The words in the flyer I'm trying to print show up white instead of black
  • 9 more comments
  • jkribbs Feb 25, 2009
    I have the same problem. I uninstalled, rebooted, reinstalled, rebooted and still the same results.
  • Anonymous Feb 26, 2009
    same problem. new black cartriges... same problem.
  • Gypsie Soul
    Gypsie Soul Dec 09, 2012
    yeah me too, tried everything even new printhead, didn't try another ink cartridge only the color it says needs to be replaced now and not both. but i just installed them today, got them 2 days ago!! UGGGGHHHHH NOTHING IS WORKING.
  • Gypsie Soul
    i have the same problem. even replaced the printhead, but now only saying the color ink needs to replaced when i know it doesn't i just installed both cartridges today. got the ink flowing they were dry and ck again definitely flowing but still saying color out. i did everything but buy new ink, what a waste of time and money!!! NOTHING WORKS!!!!! UGGGGHHH!
  • Gypsie Soul
    I have tried everything. Just got the ink cartridges and installed them. Tried everything on this post, replaced the printhead and so far it says the color needs replacing. It is brand new and the ink is flowing when i checked it. Any way to reset it??? Can't keep buying ink!! What a waste of time and money, NOTHING works!!!! UGGHHH!!! Went through this a few times already! Ready to throw Kodak thru the window and buy another brand. Save on ink my buttt!
  • letitia wheless Aug 16, 2013
    same here. Purchased Kodak esp 3.3. It ran out of ink soon after purchase and I did not use it a lot. Purchased new cartridges and it still will not work. My fault that I cannot find the reciot. fml
  • Anonymous Mar 13, 2014
    kodak esp 7 won't print black
  • Anonymous Mar 19, 2014
    Ive changed the ink cartridges and my printer wont print black??? any thoughts?
  • Anonymous Mar 26, 2014
    printer not printing in black ink. ink cartridge is full.
  • Anonymous Mar 30, 2014
    Color cartridge is just about but just put new black one in will not print
  • Gypsie Soul
    Gypsie Soul Aug 27, 2016
    lol got notice of this post I commented on, after getting TWO replacement printers I finally threw the thing away and bought an EPSON which I LOVE!! It is a powerhorse! NO problems except the END OF LIFE THING!! but i found the answer to that one and it continues to run like a champ!
Kodak ESP-3 All-in-One-Printer still says black ink catridge is low after I replaced it
There is a sensor in the cartridge which contacts with the printer. See it is clean from dirt. Try reseating the cartridge. If you use cheap cartridge rather than genuine then this could happen.
Check for updates in the Kodak website appropriate for you.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9hbnN3ZXJzL2RldGFpbC9hX2lkLzE3MzAzL34va29kYWstZXNwLTMtYWxsLWluLW9uZS1wcmludGVyLWZpcm13YXJlLS0td2luZG93cy1vcGVyYXRpbmctc3lzdGVtcy9vcmlnX2ludGYva29kYWtfYjJjX2Vu
Dec 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp 3 won't doesn't recognize the new black ink we put in
I'm having this same problem with both black and a color cartridge. I see the small scratches, so looks like they are connecting all right. The new cartridges are Kodak brand, so that's not the problem.
I'll try calling them about the print head if that might be the problem.
Nov 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a brand new Kodak ESP 3250. Not one drop of ink color or black, is coming out of the cartridge. And even so, the indicator shows a loss of ink. ! no spills inside. I am absolutely certain the...
Clean the gold section of the print cartridge's with a wet paper towel.
Also clean the gold surfaces where the cartridge meets the printer.
Wipe the contacts clean with a dry paper towel once you get no ink back on the wet paper towels. Allow about an hour for the printer to dry.
Reinstall the cartridges and try printing.
Hope This Helps.
Zeppelinx12
Mar 06, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak ESP-3 all in one printer that has a new black, and new color ink cartridge, and the printer does not print any colors. only prints black, grey, and a litte bit of greenish tint.
Inkjet printers do not like being left unused.
The color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 doesn't print black ink!
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Feb 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
MY KODAK ESP 5 WILL ONLY USE THE COLOR CARTIRDGE
take out both cartridges from ur printer,install them again. ry to print again.kodak printers works on the mechanism that even if ur printing black and white documents, it will take ink out of colour cartridge as well . try to upgrade the firmware of ur printer by going to www.kodak.com/go/downloads and downloading latest firmware from there on ur desktop,connect ur printer to computer and run that file. restart ur printer,ur issue will be resolved.
Aug 22, 2009 | Kodak 5300 All-in-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
19,071 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Michel Smith
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
