Question about Toshiba 50HP95 50 in. Plasma Television
Toshiba 50HP95 Won't turn on. Plug it in and it clicks once on then immediatley clicks off and red power button just blinks. I am a board level service tech, but don't have any idea on this one nor do I have schematics. Any ideas?
  • 2,326 Answers
Today's Plasmas and LCD are more challenging to troubleshoot to the component level as most service techs replace the entire assemblies.
I would suggest to start by measuring the voltages from the power supply to the Ysus and Zsus board, those voltages will appear for a short time since the TV goes back to shutdown mode. Check all the fuses on the Ysus and Zsus boards as well, any blow fuse will indicate that a transistor or mosfet has shorted out. Most power issues are related to the Ysus and power supply assemblies.
Posted on Jan 07, 2009
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Just unsolder the switching diode on the right and switch it with the switching diode on the left facing the back, at the bottom of the power supply board, the one that clicks, works like a charm.
Posted on Aug 03, 2013
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Tip
Toshiba 50HP95 Manual Download
Download Toshiba 50HP95 Plasma TV Manual
Would you like to review the features of the Toshiba 50HP95 Plasma TV ?
Have you lost your Toshiba 50HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 50HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 50HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Toshiba 50HP95 no ic no sound only blinking read light
Could be bad capacitors on the power board. Had a 32" polaroid w/sound no pic. Had two bad caps on ps. Replaced, good as new or better. Google bad caps so u can see what they look like. Usaully they are bulging or leaking brown ****. Hope u can solder.
Dec 26, 2011 | Toshiba 50HP95 50 in. Plasma Television
Red light blinking
Tries tv unplug,replug it back like about an hour later.The tv should now be resetting itself back to the factory setting now.The tv should work again.If still have the same problems,the power supply board is cause and the problems.That the board,where the power a/c cord plug into it.Try website Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 31, 2010 | Toshiba 50HP95 50 in. Plasma Television
The red light (off) and the green light intermittently turns itself on an off... the tv no longer turns on at all
Power supply board is dead.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 25, 2010 | Toshiba 50HP95 50 in. Plasma Television
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
50HP95 Toshiba Plasma TV No power but blinking power light
I had the same problem with my 50HP95 Toshiba Plasma TV. It would not turn on. I read online that if you unplug a connection on my TV and it turns on, it is a bad Seine board. I could not find this Seine board anywhere online. It was either out of stock or no longer available. The TV is just 5 year old. Why would they discontinue parts for it? Then I saw a video on You Tube where someone unplugged a connection in the back of his TV to fix problem. I decided to try it. I took the back off, unplugged a connection numbered PJ63A and the TV works again. So far so good. I downloaded the Service manual for this TV to find where PJ63A was.
I also called Toshiba Tech Dept. to find out if there was a chance I can cause further damage to my TV. They had no idea.
Mar 27, 2009 | Toshiba 50HP95 50 in. Plasma Television
Panasonic th-42pz77u 42ed
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
but anyway 3 circuit boards seems a lot to be replaced in a row.
hope this helps!
Mar 20, 2009 | Panasonic TH-42PZ77U TV
Toshiba 50HP95 - noise in back of tv and then turned itself off
I would contact guy at
plasmatech@gmail.com
he has great expertise and all parts for Toshiba Plasma TVs
Jan 08, 2009 | Toshiba 50HP95 50 in. Plasma Television
Toshiba 50 HP
Tenho o mesmo problema. Estou aguardando o resultado da avaliação técnica, Ja consegui os manuais técnicos e de diagramas.
Sep 05, 2008 | Toshiba 50HP95 50 in. Plasma Television
Toshiba 50HP95 50 in. Plasma Television Logo
672 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
