Question about Sony KP-41T65 41" Rear Projection Television
KP41S3U LED FLASHES 12 TIMES
I have a 1996 KP41S3U . When it comes on it led flashes 12 times. What fault does this show and on which PCB !. Somtimes only sound comes on to get picture I put it on standby then push a channel no , after another 12 flashes its fine.. (I have another KP41S3U that shows 2 led flashes Ithink its power suppy as its dead so I can pull pcbs from this for a swap). If you can suggest the correct board swap and the board is ok, ive read that the fault will still show until reset in service mode.How do I get service mode. Tried (5 vol+ pwr from stand by nothing). prg+ and prg- when held on the TV and power switch pushed after 12 flashes gives TT00. The only TT code that works is 13. This gives V2.00 50 HZ 07/06/1996. Can you help Many Thanks.
    Scholar:
  • 150 Answers
I dont think Sony has a "12" blink code, the highest (being in a newer set) is a "10", might try rechecking that, as for the code 2 that is an OCP, usually a shorted horizontal output transistor/Convergence IC's/High Voltage distribution block. My bet is the Block as HV tends to break down parts like that over time You must be careful when removing the anode leads as you can break the tip off or burn something up if not done right.
Posted on Jul 06, 2007
My machine starts to fill and then stops. It flashes 7 times. What is this error?
What is the Brand and model of your washer ?
Is it Indent ?
Many basic UK Indesit washing machines fitted with a rotary dial indicate error codes by clicking the dial continuously round and flashing the door lock light a set number of times.
If the door light (LED) flashes 7 times it means, "Heater relay stuck - check connections on heater and module (PCB)".
In my experience, this fault code usually required a replacement PCB and EEProm. A connection fault on the heater usually results in the entire washing machine going dead. Nothing will work, but the LEDs light up. This symptom can also be caused by an open circuit motor or other faults.
It's always possible for a connection fault to cause error codes but the heater relay is embedded in the PCB and if it develops a fault the whole board needs replacing. I don't recommend replacing the PCB as a DIY repair. It is an expensive part and it will not be guaranteed unless fitted by an engineer. New PCBs do not come with the micro-chip EEPROM which would also need fitting. Replacing the PCB and EEPROM yourself is risky. If the fault is not cured you cannot send the parts back.
If you have an engineer to replace the PCB and EEPROM I would imagine the cost is likely to easily be over £100. If your washing machine has a 5 year parts guarantee Indesit would supply the PCB free of charge but only if their own engineer fits it at a cost of about £90.
If you are really keen to fix this yourself and want to try another PCB there is a company that might be able to help and are happy to deal with the public called Quality Electronic Repairs (see link below)
Mar 07, 2016 | Washing Machines
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
How do i turn on my Polaroid Shuffle 4GB MP3 player?
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Jul 15, 2014 | Polaroid Audio Players & Recorders
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 13, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
How do i get the PMP80-4 to shuffle through the songs. Is there an instruction manual?
Feb 22, 2014 | Polaroid Shuffle MP3 Player
It was working fine until yesterday. It shut itself off. I powered it back on and befor the screen could come back on it shut itself off. I checked cables and uplugged it for 24 hours. The first time...
Hi Daniel,
Please check if you can access the "error code operational check" to narrow down where the fault came from.
How to enter to error code operational check.
Note : The TV must be in shutdown and not have been switched off. When the TV is switched off, the error code automatically resets to 12 (no error).
Press the buttons on the front panel "Input/Device" and "Menu" at the same time and hold it for 5 sec, activate the error code mode. The LED light will flashes denoting a two digit error code.
Example : if the error code is 22, the led will flash two times pause and then flash two times and will repeat the error code for five times.
If you can't access the error code operational check , please let me know the exact pattern of the flashes of the led light and its color. Check if it will continually flashes green to give you the caused of the symptoms and best solution.
Good luck and take care.
Nov 15, 2011 | Mitsubishi VS-50805 50" Rear Projection...
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
Dec 21, 2010 | Ruud Central System Air Conditioner
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony KP-41T65 41" Rear Projection Television Logo
145 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
