Question about Whirlpool GGQ8831L Gas Dryer
Do gas dryers have heating coils whirlpool
My dryer dosent heat up
  • 640 Answers
OK STAY WITH ME...LIL MAMA AND I WILL TALK YOU THROUGH..OK..FIRST UNPLUG THE DRYER...NOW GET A PUTTY KNIFE,,OR A SCREW DRIVER...AND STICK IN IN THE BOTTOM PANEL,,YOU WILL FEEL TO CLIPS PUSH STRAIGHT AT THE CLIPS ONE ON LEFT AND ONE ON RIGHT END OF PANEL..UNPLUG UNIT,,YOU SEE A WHITE FUSE IN FRONT OF YOU WITH TWO WIRE COMING OUT,,JUST REPLACE IT ,,OR FOR NOW AND THIS IS TEST ONLY PUT THEM TOGETHER WITH OUT FUE AND MAKE SURE THEY TOUCH NOTHING,,RAP A LITTLE TAP SO THEY DONT TOUCH ANYTHING,,,PLUG UNIT IN DO YOU HAVE HEAT NOW,,,LET ME NO ONTHEJOB,,,ALWAYS BE CAREFUL...
Posted on Jan 06, 2009
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
I replaced the fuse and the coils for my Whirlpool dryer because it would heat up and then the flame would go out after it ran for 5 - 10 minutes. Now what could it be? Whirlpool Gas Dryer LGR8648LW0
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 19, 2010 | Whirlpool Dryers
Dryer dosent allways produce heat to dry the load
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 16, 2010 | Whirlpool LGQ8000JQ Gas Dryer
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Why dosent my dryer get heat
There is a sensor for detecting airflow. If the dryer is unable to exhaust properly it will shut down the heat for safety reasons. Be sure the exhaust vent is not obstructed, and that there is good exhaust air flow. If there is insufficient exhaust, find and correct that condition.
Hope this helps.
Mar 28, 2009 | Whirlpool LGR5636L Gas Dryer
Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Whirlpool LGR8648 Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
