Question about Plumbing
Snow plow wont turn right
Plow has three wires on it up, down, and left how do i make it turn right?
  • Hayward Cowan May 11, 2010
    Did the plow come wired to the switch or did you wire it yourself. If you did what type of switch did you use?
    Scholar:
  • 104 Answers
To turn Left you need two cylenders. I think you only have one. Any one cylender will have three wires and a ground. The ground is always connected to the vehicle ground. The other two to the Single pole double throw switch. TOne wire and a ground runs the pump one way, the other wire and the ground runs the pump the opposit direction. For left and right you must have a similar pump, motor and wiring.
Posted on Feb 07, 2009
My western snow plow will not lift, it will turn left and right but will not lift ?
check for air in cylinder may have to bleed the line and cylinder
Dec 20, 2016 | Cars & Trucks
HOW TO GET WESTERN SNOW PLOW TO GO LEFT AND RIGHT
Hydraulic fluid doesn't really freeze. When it does, we wouldn't be around to see it. You need to go threw electrical. Go to there web site and see if you can get a diagram for it. Old systems are fairly easy to go threw. Newer ones have PC boards. Older ones, the stick/switches go bad first. But it always wise to loosen, then tighten the nuts that hold wires first. Corrosion sets in because it isn't used for so long.
Dec 18, 2016 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
On my boos plow lights the shield over the low eam light comes loose and breaks the bulb. this has happened three times on the right side and once on the left
try putting them back with a dot of silicone caulk in the corners (dont seal the entire thing) i had a snowmachine that was allways loosing its headlamp and i did this , never came out again
Feb 25, 2015 | Boss V-XT Poly Snow Plow
Fisher plow lock up when training right or left.
Have a 2004 hmm and plow went up and down but jerked left to right but did not turn , found it to be wire harness going thru fire wall , sheet metal wore thru wires shorting them out , pulled harness thru and shrink rapped and hooked back up been working fine.
Nov 14, 2014 | Cars & Trucks
Meyers plow blade doesn't go right
I had the same problem with my 7'6" with an e47 power unit the plow would angle left not up or right. I had to replace Meyer (B) Solenoid Valve Assembly, Red Wire . If you go to the meyers products website they have a troubleshooting chart that is extremely helpful . I found parts are alot cheaper through amazon.
Feb 03, 2014 | Meyer 6 8" Drive Pro Complete Truck Snow...
I have a myers e47 snow plow it will go up down left and right when you go all the way to the right it loks up and wont do anything
mine did the same thing bump the blade to push the cylinder back in .if low on fluid use only Meyers fluid only
Jan 21, 2014 | 1997 Dodge Ram 2500 Club Cab
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
I have a meyer e47 snow plow and when i touch the up button it goes to the left. And when i go left or right it works left and right but it wont go up. Any ideas
I would check the hand control box it sounds to me like an electrical problem, if you know a dealer, plug in a new control box, this should narrow it down.
Jan 12, 2010 | 1999 Dodge Durango
Plumbing Logo
1,471 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
