Question about Compaq Evo N600C PC Notebook
No speaker sound
My sound wont come out of my speakers unless i put a 3.5 mm headphone set halfway or 3/4 of the way in the jack it will go to the speakers but only one side. with headphones and speakers hooked up to the jack it also only plays on one side, i wonder if there is a way to fix this without having to buy another jack to replace the one i have in the computer.
  • halomage Jan 06, 2009
    Thank you, That is what i needed to hear. :)
  • Compaq Master
  • 5,568 Answers
Unfortunately, these small jacks are not very durable.
They can be constructed to turn off internal speakers when a plug is inserted into the jack or not. There are normally small bumps on contacts in the jack that are pressed upon when inserting the plug and if their spring qualities are less than good, they stay somewhat bent after the plug is removed leaving one or more channels dead.
The cost of a replacement jack is miniscule (any electronic supply that caters to hobbiests will have them) but the replacement may require extreme care. The jack could be a board-mount type with angled leads that are inserted through the board or could be attached by thin wires. With care, the board mount type is the neatest to replace but one should have some soldering skills and a good iron to avoid damaging the circuit board. The wired type makes a messy repair and demands even more skill to keep stray wires from shorting each other and one always risks breaking the thin conductors while handling them.
Posted on Jan 06, 2009
Can I connect original Harmon/Kardon Sound Sticks speakers with a 3.5 mm headphone-type jack instead of the USB it came with?
USB speakers are a different animal to standard passive or active speakers.
The USB cable will carry power and a digital signal and the speakers have circuitry to convert this into a stereo analogue signal the speakers require.
Normal active computer speakers with a 3.5 mm jack plug obtain the power from an independent power source, passive speakers require no additional power, but in both cases they use an analogue signal from the sound card.
The short answer you wanted is no...
Mar 27, 2016 | Audio Players & Recorders
Is it possible to install aux 3,5 mm plugg?
Probably not, but you can buy a 3.5 mm.-to-RCA adapter cable to hook up a device with RCA (L/R) AUDIO OUT jacks (and no 3.5 mm. headphone jacks) to your Harman Kardon speakers which, I assume, have only 3.5 mm. LINE/AUX IN jacks (1 or 2).
Jul 15, 2014 | Harman Kardon Harmon Kardon SoundStick II...
I cant get sound on my viewsonic va520
You need to add some information - what is the source for the video that you are viewing on the VA520? The VA520 has no speakers in it. If it is a desktop computer, look on the back of the computer for a green 3.5 mm stereo audio port. This is your speaker out connection. Plug in any set of computer speakers or headphones. (Computer speakers may require a USB connection or to be plugged into an AC outlet to power the speakers.) You can find cheap speakers for under $20; good speakers will be more expensive. With a laptop or some desktops, you'll find a headphone jack on the front of the computer. (This will be labeled with a small picture of a set of headphones.) The headphone jack is also a 3.5 mm stereo port.
I hope this helps.
(laptops usually have internal speakers; most desktops do not have any internal speaker anymore. If you have headphones with RCA audio plugs, you can use a RCA F/F to 3.5 mm M audio adapter to use them with the computer. A stereo system may not work with a computer.)
Jul 24, 2012 | ViewSonic VA520 15" Flat Panel LCD Monitor
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
I have Acer aspire 5741, OS: win7. The problem is that when I plug in headphones or 2.1 speakers the sound get worsed and I hardly could hear anything. I've insalled latest realtek sound drivers but that...
hi Dzhamal23.
you may need to setup the sound for your speakers.
First Check if your headphones work on rear audio panel or not. If they work there then you need to set your Realtek HD Audio to recognise your headphones. Do this:
Open Realtek HD Audio Manager from control panel or from notification area icon(a brown coloured speaker).
On the dialog box just below the close button there is written 'Device Advanced Settings' (no need to change the settings) and below this there is a Folder icon which shows tooltip text Connector Settings when you hover your mouse over it.
Click open the Dialog Connector Settings.
Tick the checkbox against Disable front panel jack detection and click OK.
i also found this on the internet.
So I have contacted Acer and I isolated the issue they dont support the issue but I have found through research that the motherboard has a problem relating to the headphone jack I have seen then listed for sale on Ebay with broken audio jacks I used a usb headphone set and received clear sound and after removing the third party software the speakers are sounding good too... if you have a nice set of mm headphones then you can buy an adapter that converts usb to mm so you can use them this way and that will prevent having to replace the faulty motherboard/audio jack
or go to this link and it will give you step by step on what to try out.
Fix Windows 7 Headphone Not Working Issue Driver Easy
Dec 01, 2017 | Acer (54.AA806.001) Sound Card
Plug for pc speakers wire
To use the speakers on the TV when you connect to a PC, get a 3.5 mm M/M audio cable (it may be called a patch cable or audio aux cable) and connect it to the PC audio in port to the left of the composite A/V ports (that's the group with 3 RCA jacks yellow (video)/red(R audio)/white (L audio)). The other end goes into the computer's line out (speaker out) port - which is generally colored green. Otherwise your regular computer speakers will play the audio.
If you want the TV's audio to output to external speakers, use the headphone jack (sometimes labels Phones, again a 3.5 mm plug) or a set of speakers/receiver that takes an optical audio connection. The optical audio jack is between the two coax connectors. Please note using the headphone jack will force the internal speakers off.
I hope this helps.
Aug 31, 2010 | Protron PLTV3250 32 in. LCD Television
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Logitech speakers :(
Hi and welcome to FixYa,
Initially, I feel uncomfortable cutting the 3 plugs, splicing them together and soldering to just one plug. What I have in mind is to use 3 barrel jacks (use stereo, the image is for a mono), splice them together and connect a single 3.5 mm plug, homemade splitter.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Logitech X-530 Computer Speakers
The speakers on my laptop do not have any sound. I can hear sound only when I plug in headphones. Is there a way to switch speakers? I have a Compag Presario v2000
You could have damaged the sensor in the 3.5 mm headphone jack so your computer does not realize that there are no headphones plugged in. If thats is the case you will have to have the sound card replaced. Another problem could be that the driver is messed up if you recently updated drivers roll back the sound cards driver or update it. Finally you can simply hook up old non usb speakers that use the headphone jack.
Jan 08, 2009 | HP Compaq Presario V2000 Notebook
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Compaq Evo N600C PC Notebook Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
