Question about Nikon D70s Digital Camera
PLEASE HELP. I CHARGED MY CAMERA FOREVER, I ALWAYS TOOK OUT BATTERY AND DS CARD MULTIPLE TIMES. IT TURNS ON , RARLEY!!! MOST THE TIME IT DOESNT TO ANYTHING=( I REALLY NEED MY CAMERA TONIGHT! I HAVENT EVEN DROPPED IT YET! IT JUST OWNT TUEN ON, ITS WEIRD. PLEASE HELP! PRACTICALLY BEGGING! HURRY! Thanks!
    Novelist:
  • 121 Answers
Someone595,
Don't panic, keep in mind to turn off the camera before you remove the SD card or change lenes. Charging the battery shouldn't take too long put it back in make sure the lens is properly locked in place, put in the SD card in then turn it on and you should be good to go. let me know I'll check back in an hour to see if that helped.
randy320sgi
Posted on Jan 06, 2009
Red battery light even with new batteries - then shuts down
Your camera can work with 2 AA sized batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period.
Always charge sets of batteries together.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) batteries and NiCd rechargeable batteries cannot be used with this camera.
If you are sure you have good batteries, also check if all contacts are clean and shiny. No oxidation is allowed. To clean contacts never use sharp tools. They can damage the camera forever.
Eventually clean contacts with a cotton swap or a dry cloth.
Also check if no debris is in the battery compartment. Just a little pice of paper can spoil all the (camera) fun.
Just to make sure, try some other batteries, then the ones you are sure of, they are fully charged. Perhaps, next time you are less convinced.
Feb 24, 2014 | FUJIFILM FinePix AV130 Compact Digital...
Camera won't turn on
If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
May 03, 2012 | Kodak EasyShare C330 Digital Camera
Card indicates memory error what can be done to correct this problem and also save dictation already on there ?
Hi cazpell,
If you're encountering a memory error, it is often caused by the battery pack. Battery packs included with the DS-4000 are rechargeable battery packs. This problem is likely to happen on the DS-4000 when a NEW battery pack is being used. The battery pack out of the box does not hold enough charge to power up the recorder through its initial start-up procedure.
1. Please turn off the recorder.
2. Remove the battery pack and memory card for 20 seconds.
3. Install the memory card in the card slot.
4. Install new AAA batteries before you turn ON the DS-4000.
5. Your battery pack may also not be fully charged. All new battery packs must be fully charged from 2.5 to 3 hours before first time use.
6. For the first week to 10 days of use, it is recommended to recharge the battery pack as often as possible. This will exercise it and improve its charge-hold capacity.
Hope it helps.
Thank you for using FixYa.
Jun 21, 2011 | Olympus DS-4000 Digital Voice Recorder
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
My Camera turns on But will not take a picture, I push the button to take a picture and it doesnt do anything! I took the batteries out, charged batteries, took out the lens, took out the card, and put...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 06, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
My DS lite wouldnt switch on whilst i was on it so
It sounds like a faulty on off switch, when you turn it on it is not contacting fully, i had this problem with my grandsons ds lite, what i did was unscrew the ds, then looked to see if the push up and down on off switch was fully contacting when switching on, when i took the case off i could turn it on, i just made sure everything was in place and put the case back on, its ok now, i could be the on off switch had dislodged ater time, and just needed re locating, its nothing to do with getting a new battery.
Oct 15, 2009 | Nintendo DS Lite Console
Camera
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Nikon D70s Digital Camera Logo
52 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
