Question about Canon DR-9080C Path-Through Scanner
Canon 9080c unable to select scan ahead unless logged in as Admin
Have several Canon 9080c scanners in corporate environment. We don't want to give users admin rights on all the pc's. When logged in as a regular user, unable to change any scanner settings. I tried giving user full permissions to the windows\twain_32 directory with no effect. Can you only fully utilize the function of these scanners by being logged in as admin?
  • 490 Answers
Try in install captureperfect in Admin mode and give full rights and select the setting you want. Log off and get into user mode and try Captureperfect. This can work. If there are not too many variations in settings required, the best is to select Autocontrast option, but you may get a samll black patch on the top.
Posted on Feb 02, 2009
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Dec 10, 2013 | Canon DR-7580
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
Mar 02, 2013 | Canon PIXMA MP160 All-In-One InkJet...
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
S. Mohan, Chennai, India
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
How can i get the total number of pages scanned by my Canon 9080C scanner
Click 'Start', 'ControlPanel', 'scanners and Camera', select 'DR9080c' and you will get the count.
S. Mohan
Aug 20, 2010 | Canon DR-9080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
234 people viewed this question
old marine
old marine
