I have a kenmore top loading washer appr. 8yrs old. It fills w/water but the agitator does not spin in the wash or rinse cycle. I can hear the motor running but thats it. Any ideas?
    Problem Solver:
  • 7 Answers
Ur coupler is broke its a 4 dollar part very easy 2 do ur self or some one come fix it 4 about 100 bucks
Posted on Jan 07, 2009
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
    Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
    Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
    I have a Kenmore top loading washer model #110 and won't agitate
    First, see the Sears parts site for your washer.
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
    Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
    I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
    Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
    These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
    Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
    Nov 14, 2009 | Kenmore 22422 Top Load Washer
    The agitate (wash cycle) does not engage-neither spin cycle
    is it a top load kenmore washer?if so the motor coupler is broken,they brake if overloaded and just get old,let me know more-mike
    Apr 16, 2009 | Washing Machines
    Washer will not agitiate or spin
    Motor coupler between motor and gearcase.
    Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore front-load washer stops at rinse cycle
    When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
    Mar 03, 2009 | Kenmore 43142 Front Load Washer
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Won't Agitate
    If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
    Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
    Washing Machines Logo
    26 people viewed this question
    Top Washing Machines Experts
