Question about Dryers
I have an obstruction in the air flow leaving the drum. I believe that too much latex backing on carpets has cloged the chamber directly behind the drum. I'm having a problem getting this chamber out of the dryer.
  • n3auq Jan 07, 2009
    The answer doesn't relate to the problem, only what not to do.
    Problem Solver:
  • 15 Answers
Do Not dry latex backed carpets in dryer. You need to have your dryer serviced.
Posted on Jan 07, 2009
Hi, i own a 2007 volvo s40 which is R H D and i wish to know how to change the polin filter, and where is it sitiuated, thanks
1. Remove the driver's side soundproofing panel
2. Remove accelerator pedal
3. Fold carpet back. Remove 3 retaining screws, and fold up cover
4. Remove filter by pulling it out behind the brake pedal
NOTE: The direction of air flow is indicated on the top of the filter.
5. To install the filter, ensure that the filter is installed with the text side acing up and so that the arrows on the filter point straight back into the vehicle
6. Install air filter by compressing it slightly and inserting it behind the brake pedal.
7. Clamp the cover in place at the rear edge. S
8. crew the cover into place at the front edge using the 3 screws.
9. Fold back the carpet.
10. Install the accelerator pedal
11. Install the soundproofing panel
Mar 12, 2011 | 2007 Volvo S40 2.4i Sedan
Water continues to flow into bowl and overflows on to the floor
If it overflows while not in use it will be the water valve. If it overflows while in use it could be the water valve or pressure switch or pressure hose kinked or cloged or pressure chamber cloged need model number for more info
Sep 29, 2010 | Washing Machines
Cabin air filter location and replacement. Owners manuel says to take to dealer for periodic changing of the carbon filtration system. Is it under the glovebox? Any tricks to opening and who could sell...
Your cabin air filter is behind the driverside carpet. pull out your floormat, pull back the carpet. now way back behind the center console theres a white plastic door. just squeeze the clips in and pull that out. now theres two cabin air filters. just pull them out with the tab. as for the replacement filters, aftermarket ones will not fit quite right and will usually leave gaps inside the airbox. oem will fit like its supposed to. I'll leave the decision up to you. youll save about 20 bucks getting an aftermarket one.
Oct 05, 2009 | 1993 Lexus Es 300
My kenmore was smoking and is not blowing cool anymore?
Hi
Please check the air filter as it might be clogged with dust, you can try to clean the air filter and re-install it. Also check the air flow from the outside condensers as that might be obstructed and leave a clearance of over 1 meter between the back of the air conditioner and the wall behind it. If still the issue is not resolved then you need to contact a qualified repair tech. as this might be due to a burned wire inside the unit.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore 72056 Air Conditioner
Washer door will not open. washer just making humming noise
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
post further comment for more help....
Apr 17, 2009 | Maytag MAH8700A Front Load Washer
OE error code
best of luck...........
Mar 29, 2009 | Maytag Neptune High Efficiency Washer...
Water wont drain
Good Luck!!
Mar 26, 2009 | LG WM-2277HW Front Load Washer
Oe error code
Feb 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Bosch WTM C3300 Dryer
I don't own this model of the Bosch dryer, but my guess is that your hot air flow path is partially blocked with lint or something else. Our heating/air flow element was blocked with a errant latex club hit the elements. I cleaned the flow path and removed the heater obstruction with good results for nearly a year to date.
Oct 25, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Error code-OE
Good Luck!!
May 27, 2008 | LG WM2016C
Dryers Logo
43 people viewed this question
Top Dryers Experts
