Question about Maytag Refrigerators
Freezer all frosted
On side by side fridge/freezer, the freezer wont defrost, the coils get filled with frost and freezer wont freeze. I defrosted manually, then the freeze was on but now coils are all filled with frost again. Fridge is Maytag Plus MSD2456DEW. HELP! Greg
I have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Posted on Jul 26, 2010
Fridge wont cool at all.
Condenser coils do not frost ....If ice (more than just frost) is present in the freezer you have a defrost problem
check the following ....
- air circulating fan in freezer
-defrost circuit .... defrost heater, defrost thermostat, and the defrost timer If you have a control logic board the defrost control is part of the logic board
Sep 06, 2015 | Frost Refrigerators
Frost in freeze and refrigerator not cooling
Your unit is in need of a auto defrost repair..There are 3 components that might need replacing..1 defrost heater..2 defrost thermostat..3 defrost mechanical timer or newer models have a computer PCB type control..usually all 3 are replaced to guarantee resolve of problem.
Jan 04, 2018 | KitchenAid Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Coils freeze up, replaced thermostat, defrost unit, mother board, only marginally works when set on 2-3
It is normal for the coils to frost evenly all over but if it's not defrosted it will build up preventing proper cooling. After replacing your defrost components make sure the frost is being melted. The motherboard determines when to defrost based you your use of the freezer/fridge. It should defrost from once a day to once every two or three days.
Is the fan in the freezer running? It won't cool right without it. It should run when the compressor runs.
Are the coils frosting evenly? Uneven frost means it is low on freon and requires a tech to repair.
Is the fan underneath the fridge near the compressor running when the compressor runs. If not It won't cool properly.
Does the compressor ever cut off as it should when it reaches the selected temp.
Jan 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
387 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
