Question about Altec Lansing inMotion iM310 Portable Speakers for iPod
Can't open/disassemble Altec Lansing im310
Hi. Just bought an im310. Sound is excellent for its size, but the material and mechanism appears to be cheap plastic @#$%. After just 2 days of use, the mechanism that opens and closes to properly position the unit and allow docking appears buggered and idiot me cannot find the receipt for warranty repairs. I have removed the only visible 4 screws in the battery and storag (??) compartments, but cannot get the unit to break apart without using considerable force. Naturally, I want to neither mark nor break the new gismo and expect there to be some 'insider trick' to split it and get to the inside mechanics. Can you please help.
  • 2 more comments
  • Anonymous Feb 22, 2009
    will not power on. How to open to check things is a puzzle
  • jmerriott Feb 28, 2009
    Same issue - would love some help...
  • mimmesmo Mar 16, 2009
    I have the same problem with a very similar model: Altec Lansing InMotion iM600... Can't open the damn thing.
  • tom496 Apr 11, 2009
    I also cannot figure out how to open the iM310.  I removed the four screws (two in battery compartment and two in sorage compartment) which appears to have loosened nothing.  Mine has two problems: (1) the rear support leg/platform is broken on the inside (the platform is attached, but swings freely on the hinge and does not support the unit - so I want to go in and see if somethig can be reconnected, and (2) when docked, my iPhone 3G plays MP3s fine, but the screen flashes "This accessory is not suported by iPhone" frentically, and if I try to simply turn of the iPhone screen off, I can't - the "Slide to Unlock" screen stays illumniated and the same message blinks about every one second.  Yes, I realize I can play tunes via 1/8" male/male cable, but I like to fix stuff.  Any help or tips greatly appreciated.    .
There is only four visible screws on the outside of the unit, which are the ones that everyone's found already.  Two are in the battery compartment, two in the storage compartment.  However I managed to find the location of the other TEN!  You need to take off the screens on top of the speaker.  The safe way I managed to do it was by using a very small flathead screwdriver and I would start at the bottom and work my way to the top on the outside edge of the speaker grill, just putting it between the grill and the plastic and turning the screwdriver up a little and inwards.
Once that's off you'll see four screws around the outside of each speaker and an additional screw sunk in above each speaker.  Once the screws are off, slowly just start to wiggle the two sides apart.  They're together tight, so just be patient and work it open slowly.
I should also mention that the ends of these speakers (that the seam doesn't seem to continue on) is actually a thin piece of plastic on each side and is stuck on with really sticky double-sided tape of some sort or rubber cement, something like that.  If you're careful, you can pull these off (slowly, once again).  It'll make pulling the two sides apart a LOT easier.
Hope this helps!
Posted on Apr 15, 2009
I don't have the solution, but maybe I can help. I just opened the bottom part, in my model, Altec Lansing inMotion iM600, the part that folds and holds the iPod. I had to open it because I tried closing with the iPod Touch connected - forgot it - and broke the connector. I was trying to fix it. Apparently I was able to push it a bit and fixed. Will send the link to the photos with a tip on how to open. I didn't broke the folding unit, but had some scratches trying to figure out.
Posted on Mar 16, 2009
How to Choose the Sizes of Plastic Lockers?
The plastic locker is one of storage cabinets, which is made of plastic materials. It can also be called as the sorting cabinet. This kind of plastic locker adopts the multilayer splicing design. Each layer has enough space for people to place a variety of items, which is very useful for the classification and arrangement of items and suitable for modern people's needs of home cleaning.
The advantages of plastic lockers
From the view of materials, the materials of the plastic locker are environmentally friendly. They are oil and acid resistant , non-toxic, tasteless and are very conducive to health.
From the view of convenience, generally there are wheels under the plastic locker. Thelocker is a piece of labor saving furniture, which is convenient for people to move it without needing too many efforts.
From the view of performance, the plastic locker can greatly save home space with light weight. It can be folded, disassembled and assembled, which is convenient for people to put it in order. When it is piled up, it also looks neat and beautiful. Also, it has great bearing strength. It is very cheap and is cost-effective, which make it a home essential.
How to choose the sizes of plastic lockers
The plastic locker has various forms and sizes. Customers can choose it according to their own interests and needs. The size of the place where the locker will be put should be measured in advance, and then the customer can measure the length, width and height of the actual locker when they purchase it. The locker usually adopts the multilayer design. The number of layers can be designed according to the actual needs of customers and it is not always fixed. The common sizes of lockers are: 33 X 43 X 63(cm), 57 X 42 X 98(cm), 50 X 45 X 79(cm).
Choose the sizes of lockers from the use of plastic lockers
The plastic locker is available in our daily life. If you use them to sort small items, you can buy small lockers. If you want to arrange more things, you can buy a multi-tier locker, and then sort item layer by layer. Some people use it to place the clothes, and there are also plastic lockers for clothes on the market now. You can choose lockers with different sizes for different use, and you can always find one suitable for your needs.
Plastic lockers are becoming more and more popular because they are highly cost-effective. Are you looking for such a locker? Plastic Locker Manufacturer ABS Locker Factory China Locker Company
Aug 07, 2017 | Office Equipment & Supplies
Cast Acrylic
Acrylic is a crystal clear thermoplastic material possessing excellent mechanical and chemical properties. Outstanding optical qualities and resistance to both sunlight and outdoor weathering make acrylic an ideal glazing material. Acrylic can be easily cemented, making it an extremely versatile material. Cast transparent acrylic sheet has many advantages, such as excellent transparency, light weight and good flexibility, superior weather resistance, good chemical resistance ,good impact strength as well as easy to drill, cut and polish.
on Oct 30, 2015 | Miscellaneous
I took my Tissot automatic PSC 200 in for service and the repair shop said it is a fake because it has plastic parts. He said a watch of tis quality doesn't use plastic parts in it.
Not entirely true. Most watches in a range will be assembled with a standard-sized time mechanism. So the manufacturer can "Bulk-out" the mechanism with a plastic housing to get it to sit into the bigger watch enclosures. I have several Tissot's, so I change the batteries myself. A few have plastic frames to bed-in the mechanism. You'd need to move to high end ($5k-10k+) watches to avoid plastic. A PSC200 retails for around $1000? There are a few basic checks you can do to re-assure yourself that its legit. (1) Did it come in the standard Tissot box, complete with history booklet, warranty booklet and stamped retailers warranty card? (2) Is there an engraved/embossed Tissot detail on the back cover, with model number, , sometimes a collection serial number, waterproof details etc. (3) Is the face scratch-proof crystal or does it sound thin and cheap when you tap it? (4) Are the second / minute markers and fractional-second markers clearly defined, or are they a cheap and blurry paint job? (5) Are the minute and second hands precision cut, with crisp sharp edges, or are the pressed tin with 'soft' rounded edges? (6) Does it have tiny but clearly legible "Swiss Made" text around the 6 O'Clock position? If you're concerned, bring it to another Tissot retailer and ask them to check it out. They would be more familiar with the Tissot range and manufacturing techniques.
Sep 05, 2015 | Tissot Watches
I bought a Sony MP3 Walkman and Altec Lansing IM510 Speaker System that has a docking station for a 30 pin adapter; is there an adapter made to solve this problem?
Yes!!! Check the voltage size, get a docking station 30 pin adapter, which has the same output and input voltage size. and thats gonna solve it for you ok.
Feb 29, 2012 | Sony Walkman Video NWZA818 MP3 Player
Disassemble Altec Lansing T612
The front of the Alec Lansing t612 got smudged with glue. How doiremovetkhespeakercover so I can clean the cover
Dec 06, 2011 | Altec Lansing T612 Remote Control Speaker...
I have been given a Altec Lansing iM310 speaker and in the box there are a few different sized dock adapters. I put the one that fit my ipod best in, and my ipod sits nicely and works. Since then I have...
Hi there , not long ago I was having issues with my VS 2420
I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following
Contact: , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Mar 20, 2011 | Altec Lansing inMotion iM310 Portable...
How to disassemble altec lansing 220 speaker
See if the front cover can be lifted by carefully prying. The speakers may be mounted by screws - remove the screws.
Dec 13, 2010 | Altec Lansing 220 Computer Speakers
What is plastic pollution
Plastic is one of the few new chemical materials which pose environmental problem. Polyethylene, polyvinyl chloride, polystyrene is largely used in the manufacture of plastics. Synthetic polymers are easily molded into complex shapes, have high chemical resistance, and are more or less elastic. Some can be formed into fibers or thin transparent films. These properties have made them popular in many durable or disposable goods and for packaging materials. These materials have molecular weight ranging from several thousands to 1,50,000. Excessive molecular size seems to be mainly responsible for the resistance of these chemicals to biodegradation and their persistence in soil environment for a long time.
Plastic in the environment is regarded to be more an aesthetic nuisance than a hazard, since the material is biologically quite inert. The plastic industry in the US alone is $ 50 billion per year and is obviously a tempting market for biotechnolo gical enterprises. Biotechnological processes are being developed as an alternative to existing route or to get new biodegradable biopolymers . 20% of solid municipal wastes in US is plastic. Non-degradable plastics accumulate at the rate of 25 million tonnes per year. According to an estimate more than 100 million tonnes of plastic is produced every year all over the world. In India it is only 2 million tonnes. In India use of plastic is 2 kg per person per year while in European countries it is 60 kg per person per year while that in US it is 80 kg per person per year.
Plastics are used because they are easy and cheap to make and they can last a long time. Unfortunately these same useful qualities can make plastic a huge pollution problem. Because the plastic is cheap it gets discarded easily and its persistence in the environment can do great harm. Urbanisation has added to the plastic pollution in concentrated form in cities. Plastic thrown on land can enter into drainage lines and chokes them resulting into floods in local areas in cities as experienced in Mumbai, India in 1998. It was claimed in one of the programmes on TV Channel that eating plastic bags results in death of 100 cattles per day in U.P. in India. In stomach of one dead cow, as much as 35 kg of plastic was found. Because plastic does not decompose, and requires high energy ultra-violet light to break down, the amount of plastic waste in our oceans is steadily increasing. More than 90% of the articles found on the sea beaches contained plastic. The plastic rubbish found on beaches near urban areas tends to originate from use on land, such as packaging material used to wrap around other goods.
Take care.
Aug 27, 2010 | Watches
When I plug in my Ipod to the inMotion im310 portable speaker the Ipod screen says it is not supported, and it worked this morning.
Check the pins on the speaker and on the plugin on the iPod, that's the problem usually. Also, check if the iPod is truly compatible, even if it worked before it may not be. I have seen car chargers for say a 2G iPhone work for a bit then say incompatible, it happens. Here are the compatible iPods for the iM310:
Plays and charges
iPod mini;
iPod nano 1G, 2G, 3G, 4G;
iPod classic 3G, 4G, 5G, 5.5G, 6G;
iPod touch 1G, 2G
Apr 10, 2010 | Altec Lansing inMotion iM310 Portable...
Altec Lansing inMotion iM310 Portable Speakers for iPod  Logo
3,041 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
