I wish to overclock my cpu and I7 920 in a gateway FX 6200-01e
  • MrJeebs May 11, 2010
    I can find no information for a Gateway FX 6200-01e.
    More info is needed about your system specs and it's components.
    President:
  • 948 Answers
Overclocking name brand computers isn't generally a good idea. They use the cheapest parts available and the overclocking options are quite limited in most cases.
If you want to try anyway keep in mind you can make your system unbootable and make it impossible to fix. But post what cpu you have and how fast you want to go, let's see if it's possible.
Posted on Jan 08, 2009
Overclocking
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
How do I overclock my cpu
Hello
Some CPU's overclock with diffirent methods, so, you do not specify which you are using, so, i googled step by step guide to overclock CPU. I found detailed instructions on how to overclock different systems. Hope this can help you.
Best regards.
Sep 30, 2009 | Dell Computers & Internet
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Overclocking t-mobile wing
[WARNING - Overclocking your CPU will at least reduce the life of your processor but may fry it at worst - USE CAUTION]
There are a couple of apps you can use to do this:
OmapClock
BatteryStatus
I prefer Battery Status because it remembers your CPU overclock whereas OmapClock requires you to reset your CPU on wakeup. Also, BS has a "CPU Scaler" function (UNDERclocks your phone when it is not in use, then OVERclocks it when you wake it up...Pretty cool)
Anyway you will get instructions on the site on how to use each one specifically. They are really easy to use.
Jun 23, 2009 | T-Mobile Wing™ Smartphone
Changing FSB & Voltages
Hi there.
You can change the front side bus in the bios if the bios supports it, if it does be very careful not to overclock the processor to much as you can cause damage to the motherboard and blow the processor up, also bear in mind that cooling is very important when it comes to overclocking.
Good luck and thanks for using FixYa!!
May 13, 2009 | Gateway Tabor 3 (4000532) Motherboard
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Max processor support
Believe the Aspire runs a 939 chip, if that is the case -AMD Athlon FX-60 Dual Core @ 2.6Ghz
-AMD Opteron 185 Dual Core @ 2.6Ghz (best Overclocker @ ~3.2ghz) LINK this is for cpu-z to see what processor id, fsb etc,
Mar 14, 2008 | Computers & Internet
Nvidia 6600 256 mb agp
Check the temps of your card using rivatuner and the cpu with speedfan to see if they are overheating.
Are you running either overclocked?
Jan 05, 2008 | XFX GeForce FX 6800 (256 MB) Graphic Card
Computers & Internet Logo
417 people viewed this question
David Payne
David Payne
