Question about Mitsubishi Televison & Video
Lamp comes on but no picture where are fuses?
62" mitsubichi WD-62725
  • nunez37 Jan 06, 2009
    Problem Solver:
  • 15 Answers
If the lamps come on then the problem is not the fuses. Chances are that an component in the Video Circuity has failed and you are not getting any signal to sent to the projection guns. It could also be a problem with the tuner circuit. If your not a service tech I suggest that you refrain from poking around on the boards since each of the the boards that I'm referring to can give you a massive shock that could result in DEATH. Contact a service shop, describe your problem and get an estimate. This is the best solution for the problem you are having.
Posted on Jan 06, 2009
Replaced my lamp, when i push power it powers up for a few seconds then shuts off and the red lamp button comes on again.. wd 62725
Thats usually caused by failed capacitors on the Power board. The mitsubishi repair kit called the V26 Chassis DLP DM / Power repair kit will often repair that. Its available from and contains the capacitors and the CD with repair instructions.
Nov 05, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi diamond WD-62725 the lamp light was on so i ordered a new replacement for it I installed the new lamp and the picture looks brighter than ever remember seeing it but the lamp light is...
we have the same brand tv but the 65" model. had a 4 year warranty just in case the lamps went out. the lamp went out and we called conn's to come out and fix the tv. the repairman replaced the lamp, and then he said to unplug the tv from the wall or the strip it is plugged into and wait 5 minutes and then plug it back in. he left and said to call him back if that did not work. did what he said and it fixed the problem. try unplugging the tv for 5 minutes and plug it back in and see if that might take care of your problem.
Jun 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Time to replace the lamp, this is a simple process that 98% of tv owners / consumer can do on your own,you do not need a technician to do this, there are simple instructions on how to do this in the owners manual and / or some of the mitsubishi's have instructions right on the back of the tv set where the lamp access door is.Good luck!
Nov 24, 2009 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
