Question about LG Flatron L1715S 17" LCD Monitor
Monitor malfunction Hi friend, I have to restart my PC several times and wait for almost two hours tell it works.. First I see the Motherboard Logo and Info for tow seconds then only one or tow monitor's blinck , tell the I hear desktop sound starts, I can see the desktop for a second by pressing monitor powere off and on.. I have to restart computer for alsmot 50 times to get the monitor works properly.. I opened the monitor face and tried to fix the problem ,, but were unable Can you help me?? Thanks Jay
  • Anonymous Jan 06, 2009
    Thank you so much, I got a note book (lap top) compaq presario 2500 , I connected the PC to the Notebook's monitor,, trying to use NB monitor,,, I started both PC and NB ,, the monitor shows notebook wondows,, and could hear the other computer starts ,, ..
    I am sorry ,, I don't know how to use the notebook monitor for another pc..
    I do believe that the PC garaphic card is working properly beacause the monitor PC monitor were doing good after was heated up !!!
    should I try to change the connection cable??
    I also doubt ...
    I am sorry,,, I am in Egypt,, and I also unable to depend on a right techician
    Thanks again
  • obadi Jan 07, 2009
    Hi my friend,
    I am still facing the same problem,, (unable to try my notebook), I guess that the pc is working properly,,, due to the reason that the VGA card once the LCD monitor works properly after the repeated restarts ,,
    The question is why the monitor needs lots of time to be heated,?
    I tried to turn off the computer and restart it within few minuets and was doing well,, .. which that means the monitor was still hot !!!
    Thank you again my friend
    Jay
    Genius:
  • 1,665 Answers
Hi!
You might also try to connect another monitor, to check if has the same behavior. In this case the problem is generated at graphics card or from loosen cable connections.
Posted on Jan 06, 2009
Dear admin, i would like to ask you something... i have monitor ACER AL1716.. recently when i started my PC, the monitor suddenly turn on and off continously (you know when we turn on monitor, it showed...
I suspect that the problem is with your PC, and in particular your video card. The fact that your monitor is displaying the logo indicates that the monitor is not receiving a signal from your computer. You may want to try hooking the monitor up to another PC and see if that is the problem. The fact that your monitor turned off and on for a few times also indicated that the signal from the PC video card was sporadic and finally failed leaving you with the monitor logo. Disconnect the PC from the monitor and see if the logo is there. Also check the cable from your video card to your monitor to see if the cable is bad. You may have to borrow a video cable from a friend to test this out.
Apr 22, 2011 | Acer Computers & Internet
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Jan 19, 2011 | Toshiba Satellite L675-S7048 Notebook
Dear Sir, Ms, I need your support hope you help me i have one mother board hp logo intel D945 Pin less Processor 3G DD2 512 RAB but no display coming 1st time me on CPU green lite signal but after 5 sec...
hi my friend. i'm an iranian.
do as i say:
1- remove all the cables of your PC.
2- open the PC Case.
3- remove the Battery From yur Motherboard.
4- wait 15 minutes.
5- assemble the battery again and turn on your PC.
Jan 17, 2011 | Intel D945GNTLKR Motherboard
Computer boots until "press del" screen and restarts continuously
Hello
You answered your problem my friend
Its a ram problem,try to take out the corrupted ram ( slot1) and start your computer.
Generally this Stop message indicates that a kernel-mode process or driver attempted to access a memory address to which it did not have permission to access. The most common cause of this error is an incorrect or corrupted pointer that references an incorrect location in memory. . When it occurs in kernel mode, it generates a STOP 0x0000000A message. If you encounter this error while upgrading to a newer version of Windows, it might be caused by a device driver, a system service, a virus scanner, or a backup tool that is incompatible with the new version.
Jan 13, 2010 | ASUS P5S800-VM SiS 661FX/964 LGA775 DDR...
I was trying add another monitor and now there both blank, what can i do??
Good day sir, hi it seems you are having problems with your monitor. Let us first try to run the PC using only one monitor.
  1. PC is off, remove your 2nd graphics board by opening the side panels, locate the CMOS jumper, usually its near the battery, the setting is 1 2, place the jumper to 2 3 momentarily, after about 3 seconds, place it back to 1 2. If you cannot find the CMOS jumper, just remove the battery.
  2. connect the monitor to its built in graphics vga.
  3. turn on pc, as this point you should see the video on your monitor.
  4. PC is off, place back your battery if you have remove it. check to see if your 2nd graphics board is good, test it on other pc.
  5. if your 2nd graphics board is good. Install it on the motherboard. connect a second monitor.
  6. power on the PC, you should see on one monitor the boot up, and on the other monitor a message. just wait for windows to boot up. you will see the other monitor be an extension of your desktop.
  7. Make necessary settings for both monitor. Thats it.
If you still cant operate both display, do it several times. If still nothing happens review your work, get help from a friend who knows.
Nov 05, 2009 | Dell Dimension E520 PC Desktop
Is video card/motherboard dead?
Do you normally "logon" to the computer or does it load completely by itself.
If you wait for the system to "settle" you can test the computer w/o the monitor:
1. Press the "windows logo" key on the lower left of your keyboard
2. Press the letter R
3 Type WRITE
4. Type a few random letters ~ran~dom~
5. Press this three key sequence:
[Alt]F [P]
(Alt & F) together then the P key
Your random document will print if the computer is actually running.
ok, I suggest you reset your BIOS by removing the mobo battery or by shorting the "reset" pins next to the nattery or BIOS chip.
Go from there...
Sep 22, 2009 | HP Pavilion MX70 17" CRT Monitor
LCD MoNITOR no Signal
The problem lies with your video card. The fact that it worked on your friends computer proves that it is not your monitor. Some motherboards have two video adapters. One on a video card and one on the motherboard. You need to open your PC case and see if you have one or two. If you have two then you can try the other one. Otherwise, replacing the video card will correct it. However, if the only video adapter is the one connected to your motherboard then the motherboard has to be replaced. If you have any questions let me know.
Please vote on this solution before logging out.
Feb 04, 2009 | AcerPower F1 PC Desktop
System restarts automatically
1st) I would suggest disconnect EVERYTHING from the motherboard. Keep keyboard, mouse and of cause the monitor.turn on....wait your 10-15 minutes, play with the keyboard, flutzz with the mouse..
Nothing happens,TURN OFF cpu, add ONE other device, continue doing the same thing until something happens after a device is installed, that could be your problem. 2nd) your turning on and off the power supply could cause it to crash, then THAT is your problem.too Low or too high power supply voltages causes your cpu to reset in order to protect itself {By forcing the power supply to "crase & burn" u forced the issue.
Apr 23, 2008 | ASUS P5PE-VM Motherboard
Stuck on logo screen
I hate to tell you, but that is bad news. But before we jump to any conclusions, first open up the computer and look for the BIOS reset jumper on the motherboard, if you find it switch it to clear CMOS for around 20-30 seconds and then put it back on normal and see if it boots. If it doesn't, there isn't much more we can do, as your motherboard most likely decided to keel over and die.
Apr 09, 2008 | Medion MD-1704 PC Desktop
LG Flatron L1715S 17" LCD Monitor Logo
101 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
