Question about Acer Aspire 5920-6727 Notebook
Media buttons wont work
The touchpad media buttons on the right side of my keyboard wont work i cant find any configuration settings anywhere in my control panel , and it doesnt even show up by my input devices, do u have any advice for me please?
  • Anonymous Apr 15, 2009
    my media touchpad buttons did work but have stopped working with realplayer over the past week i think after i installed a registry fixer not sure if that was the problem but the deffo did work before this.
    Genius:
  • 1,019 Answers
Check to see if the computers devices, are installed Correctly.
My Computer/Control Panel/System/Device Manager.
Also check the manufacturers website, for any program/application associated with the keyboard Or Media button Application.
Thankyou for using Fixya.
mike @ compurepair.
Posted on Jan 19, 2009
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
My laptop touchpad button not working
most likely, it already needs a replacement, but do try to uninstall and reinstall your touchpad driver and make sure your touchpad settings are correctly configured. you can also try to use the drivers and utilities CD from dell to run a test on the touchpad to see if they will respond to determine if it is a hardware level
Mar 12, 2011 | Dell XPS M2010 Wireless Bluetooth Keyboard
Dell inspiron 1545 mouse pad not working
You need to install the Dell touchpad drivers and application from the Dell support website to access the properties. You can download the drivers from the link after you select the correct Operating system version: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=. Save the file on desktop and right click on it, to Run as Administrator. Install the drivers and reboot your system. Now you would be able to access the Touchpad properties from the Mouse properties in Control Panel.
Feb 19, 2010 | Dell F3534 Touchpad
I cant scroll with my touch pad
tried to press on Fn+ F9 key on your keyboard. that will enable your touchpad. Also, checked on synaptic configuration. Synaptic is the touchpad driver on most laptop. You can go to Control Panel > Mouse > Device Settings > Choose your touchpad device > Settings > Tapping
good luck
Nov 29, 2009 | HP Compaq 236076-001 Touchpad
My right click menu pop's up when ever i try to click on my laptop anywhere, i have a DELL inspiron 1520.
is your pointer set to be opposite... go into control panel and mouse options, and see if you accidentally switched your mouse clicker buttons.... try clicking with the right click, does it still open your 'right-click' menu? does it work normal on an external mouse?
maybe its just a setting issue,... if not then prolly need a new mouse pad...
Sep 25, 2009 | Dell F3534 Touchpad
Samsung q210 keyboard not working
There is a small ribbon cable that will pop out real easy when you open it up. There are actually 2, one for the keyboard and one for the touchpad. This can be a little difficult to put back in the slot and close the laptop back up without it popping out again as the cable is not very long. If you have a lot of patience, you should be able to get it. Just take your time and remember to close the lock on the connector where the ribbon cable slides in.
Aug 26, 2009 | Computers & Internet
Quickplay touchpad above keyboard
The following illustration and table describe the computer TouchPad.
(6)
TouchPad on/off button Enables/disables the TouchPad.
Component Description
(1)
TouchPad light Blue: TouchPad is enabled.
Amber: TouchPad is disabled.
(2) TouchPad* Moves the pointer and selects or activates items on the screen.
(3) Left TouchPad button* Functions like the left button on an external mouse.
(4) Right TouchPad button* Functions like the right button on an external mouse.
(5) TouchPad scroll zone* Allows you to scroll up or down.
(6) TouchPad on/off button Enables/disables the TouchPad.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 08, 2009 | HP Pavilion dv9000z Notebook
My keyboard and touchpad is not working..
attach a usb keyboard to the laptop, then check
Nov 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
XPS One Keyboard's Characters not functioning
Try to re-sync the keyboard to the computer. Here’s the procedure:
1) Turn the computer on.
2) Turn on the keyboard
3) Press the sync button on the rear of your computer’s left speaker.
4) Press the sync button on the keyboard. ( I believe it’s on the bottom of keyboard)
The sync button has a symbol next to it, (2 arrows going in clockwise direction).
Ensure that the keyboard battery has not run low.
If that doesn’t work, look for a Bluetooth icon in the lower right hand corner of your desktop and double click on it to open the Bluetooth configuration utility. See if there’s a configuration file for the keyboard. If there is, delete it and then re-detect Bluetooth devices.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 20, 2008 | Dell Inspiron XPS Gaming Mouse Pad KU170
Acer Aspire 5920-6727 Notebook Logo
219 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
