Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green or blue vertical lines on my WD52525
When ever I'm watching the TV I get these vertical lines. At first they are very light you almost can't see them. After 15 minutes sometime an hour they start to get very thick and you can baely see the picture.
They also seem to flicker. I had the TV repaired twice before I got this problem. 1st - lamp was changed, 2nd - powersupply was replaced.
about a year later I get this problem. I was going to replace the lamp but I want to make sure that this problem has something to do with the lamp.
Thanks dubbie021670@gmail.com edward.dubon@merrillcorp.com
  • 179 Answers
It is not the lamp. the DM board is causing this problem. if the DM is going bad the FMT is not far behind. it will cost you $250.00 plus shipping one way. see www.tv-techs.com
Posted on Jan 09, 2009
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
MODEL # PT-52LCX15. GREEN AND BLUE SPOT ON SCREEN.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: http://www.discount-merchant.com/PANASONIC-521A2C52-p/1177904.htm Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines and you can see the goast chanel behind the green lines. On pic in a pic setting the pic. chanel is...
Exact same thing happened to me last night. The TV only received High Def chanles. When switched to reg. chanels, there are green vertical lines. Light is definitely on and visible in the back. Now goes out after abut 30 sec. Misery loves company. Will watch the site for a solution. 4yrs. old just went off extended warranty 45 days ago. damn
Feb 12, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi modle# WD52525 serial# 122342
Bad capacitors on the FMT there are 3 1000uf 16v capacitors that will cause that symptom. Your onscreen menu is unaffected right? If you need more info or a link to the service manual for thet model you can get the service manual at this link.
http://servicemanuals.vstore.ca/
Jun 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD52525 had a blue screen when turned off
Perfect Blue screen usually means video problems. Leave unplugged and try again to make sure.
Aug 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
