Question about Dryers
Screeching at spin cycle
There is this un-Godly noise at the spin cycle. the machine still works but it is now this noise. please help!!!
There are a few things that it could be. The simplest is the fan which blows the air across the element is impinging on the back panel. This is relatively easy to fix, the fan is usually mounted directly driven from the back of the motor and held on by a spring washer or circlip.
Remove the back panel and rotate the drum by hand, you should be able to see the plastic fan catching on the metal of the back panel. A new fan costs very little and is very easy to replace with standard household tools.
Alternatively the motor bearings could be on their way out. This is more annoying to fix - get the engineer in for it. Again rotating the drum by hand, rock it back and forth you will feel a grinding transmitted through the belt (very worn bearings) or on the motor itself.
Posted on Jan 07, 2009
My Maytag washer model MAV208DAWWmakes a loud screech at the end of the spin cycle, and the clothes are sill wet
That is the brake. Your clutch maybe wearing out. Or the belt maybe slipping because the rollers for the motor maybe wearing out.
Jan 15, 2016 | Maytag Washing Machines
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Maytag centennial washer why does it only run on the spin cycle?
Does your machine have a lock/start button?
It may very well be that the selector dial has some internal looseness or corrosion. Has the top control panel been wet?
May 26, 2014 | Washing Machines
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud screeching noise when the wash and spin cycle ends
You either have something caught between the tub and basket or a bearing bad.
Eric
Jun 29, 2009 | Maytag Washing Machines
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Dryers Logo
50 people viewed this question
Top Dryers Experts
