Question about Lexmark Wheelwriter 1500 Typewriter
Type is faded and old looking even with new ribbon.
Type is not dark.
I have a IBM wheelwriter 1500 by Lexmark. It was typing fine and I changed the ribbon. Now it types like an old carbon ribbon, not dark like it had been typing. Usually a typewriter has a pressure sensor on it for the pressure you want the key to hit the ribbon and I can't find it on the typewriter. Can you give me suggestions on how to make my typewriter print dark? Thanks for any help.
  • 328 Answers
If the ribbon is old, you have to hand feed a few feet of it or just type a few lines of print and it should eventually start to get darker. But, also as DickyO suggested, look for anything that may have fallen inside or under the ribbon area that may be blockint the hammer.
Posted on Jan 12, 2009
  • Lexmark Master
  • 3,594 Answers
Put in a multi part form, if the carbons print well then try a fresh ribbon,. not one that has been sitting around for a long time. If it is bad check for debris around the print hammer, If its clean either the print solenoid is gummy or the solenoid cap is broken.
DickyO
Posted on Jan 07, 2009
Hi we have an old ibm typewriter. I changed the ribbon and the wheel. I cleaned everything but still prints half of the letters. The top part to be exact.
There should be an adjustment on the head that sets the angle of the strike for the wheel. Unfortunatley there are no diagrams available for this technology
Jan 06, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
IBM 1500 by Lexmark
If it is moving as the hammer is struck, then it's one of two things. Either the hammer is moving too slowly, or the ribbon is moving too quickly. Since this is a rather old machine, it seems more likely things would slow down than speed up. I'd check the hammer solenoid. See if it's dirty, or needs lubricated. I wish I could give you more advice on this, but I am not familiar with this specific model, and was unable to find any kind of service manual, or troubleshooting information for it.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a...
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Jan 02, 2011 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
My Wheelwriter 5 types faded and incomplete letters. We changed to a new ribbon, but problem is still there. Seems the pressure is not hard enough.
The solenoid for the hammer is probably sticky or the pad is worn.
This requires disassembly for cleaning, lube or replacing the pad.
Jan 25, 2010 | IBM Wheelwriter 30 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter won't type
The most likely problem is that the plastic cap on the print solenoid is broken they are available but a little tricky to install.
DickyO
Oct 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5
Get a new laser printer, or even inkjet. They can be had for under a hundred bucks. It'll cost you that to get someone old enough to know what a wheelwriter is to come and look it...
Jan 08, 2008 | Lexmark Wheelwriter 15 Series II...
IBM 1500 by Lexmark
It sounds to me like the impression is to heavy try holding the code key down and pressing the "Q" key until the "1" light is lit.
Lexmark Wheelwriter 1500 Typewriter Logo
194 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
