Question about Samsung HL-S4266W 42" HDTV
Samsung flat screen problems
I have a samsung 42 inch flat screen it is less then a year old i seem to have ALOT of problems with it turning on it trys for about 5 minutes and then when it finally does turn on it has all sorts of distorted colored picels all over the screen then i have to turn it off and then on again and it works fine, it also has wierd blocks that are slightly discolored about 4"x4" sections
  • edwall35 Jan 06, 2009
    we moved and seem to have lost all the paperwork for the guarentee
  • 4 Answers
You will have a years guantee
Posted on Jan 06, 2009
42 inch plasma Samsung less than a year old with a crack in left corner has sound black screen??
Hi, If the warrenty is still good bring it back to where you bought it. In time the screen will go totally black. So replace it. Good luck.
Jun 20, 2011 | Televison & Video
My 42" Samsung Flat screen
IS HE SCREEN TOTALLY RED !! if yes check power supply all voltages if normal replace x board
Apr 26, 2010 | Samsung SPN4235 42 in. Plasma HDTV
My 46 inch Sanyo flat screen turns on and right off again
Might be worth it if it cost over 500.00 dollars, I had a simular problem with a Yamaha HTR receiver... the cause was the power adapter/converter was overheating... so it sounds like something along those lines... It cost me 129.00 dollars to fix my receiver so I would say 100.00 dollars or less... I saw a 42" LCD at the local electronic's store selling New ones for about 400.00 now..
Mar 25, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
42 Inch Samsung Flatscreen; 1.5 years old. Won't
First test the wall outlet, try plugging a lamp into the same outlet see if it works. If the outlet works then read the following below. If the wall outlet doesn't work then plug the TV into another outlet.
If its not the wall outlet:
Unfortunately the power supply has a problem sustaining DC output. This can be caused from several fault scenarios. Get someone who is technically savvy and I will show them via e-mail what to test to fix this problem for you. Or you can take it to your local repair center.
Dec 20, 2009 | Samsung HP-T4254 42 in. Plasma Television
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
Sep 01, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
No picture or sound
This type of repair might not be a DIY since requires the use of a multimeter to check all the voltages from the power supply to all the circuitry in your plasma.
First step should be to measure all the voltages to the Y and X sustainer boards and since you do not have audio as well to check the 12 volts source as well.
If your plasma is less then a year old, still cover under manufacturers warranty.
Oct 20, 2008 | Samsung SP-S4223 42 in. Plasma EDTV
Samsumg plasma tv 42
it sounds like the panel is bad..if it is less then a year old you should contact samsung
Nov 08, 2007 | Samsung HP-S4253 Television
Samsung HL-S4266W 42" HDTV Logo
1,484 people viewed this question
Henry  Thomas
Henry Thomas
