Question about Humminbird Smartcast Rf 35 Dual Display Wrist Sonar
Humminbird rf15 menu says "waiting for signal"
Th rf15 unit displays "waiting for signal" and stays on that
  • 76 Answers
The remote transmitter needs to be in the water for the rf15 to pick up a signal. (green peice has to be in the water).
Mike
Posted on Sep 26, 2009
Will power up, but won't advance to menu
May require a software update.
register your unit at OnixSeries (this is a link to humminbird)
On your "My humminbird" page you will find free software updates for your particular unit.
download the latest update to an SD card and follow the instructions for the installation process.
Apr 20, 2015 | Humminbird 581I Hd Di Sonar/Gps Combo
My unit allways stay in simulation mode how to start it working
Start-Up Options Menu
Press the MENU key when the Title screen is displayed to
access the Start-Up Options menu.
Use the UP or DOWN 4-WAY Cursor keys to position the
cursor, then the RIGHT Cursor key to select one of the
following choices. If you wait too long, the system will
default to whichever menu mode happens to be highlighted:
• Normal
• Simulator
• System Status
Feb 27, 2014 | Humminbird 595c GPS Receiver
My hummingbird rf15 smartcast fish finder has stopped scanning.it still provides the water temperature but it no longer displays the depth and does not scan the bottom.
The Smartcast system uses the wireless version of a simple transducer and thermometer to locate fish, show structure and water temperature. From your description, it sounds like the transducer portion of the Smartcast device has stopped working.
Transducers are both simple and complex, sturdy and delicate. Here is a Science Minute: A fish finder electrical signal is sent to the transducer. The electrical signal to energize the transducer crystal is generated by an amplifier. The energized crystal reverberates at a particular frequency, to convert the electrical signal into mechanical acoustic or sound energy. The acoustic energy or sound waves causes oscillation of the water molecules through which the sound travels. The sound is pulsed out in a defined beam. These do not travel out in a straight line but in a wave pattern. The acoustic pulse travels through the water at a rate of approximately 4800 ft (1500m) per second in saltwater and 4920 ft/sec in fresh water.
The problem is that the crystal in all transducers (permanent mount, thru-hull mount and castable) is delicate. It is a crystal. Unfortunately the warranty on most of these is six months, and unless yours is newer than that, you may need to buy a replacement castable. The handheld unit should still work. While I think the idea of knowing what is "over there" is a good one for shore fishing, I haven't bought these systems because I could never get over the idea that repetitive casting of a crystal, no matter how well-housed, was a good idea. Good luck.
Sep 27, 2011 | Humminbird Smartcast Rf35
The screen is not displaying anything but tempeture only a black line across the top of the screen
Hi Andy, check the pin contacts on the transducer and unit, if they are ok then the transducer needs to be replaced, regards Phil.
Sep 27, 2011 | Humminbird Smartcast RF15 Fishfinder
Stays in the display mode only, tried turning it off and on , unplugging and going through all of the options
Contact our customer service group and they should be able to help you out. The Humminbird Service number is 800-633-1468.
Feb 11, 2011 | Humminbird 525 Fishfinder
Manuel for humminbird 565 dual beam fishfinder with 640 vertical pixels
If you go to Humminbirds Website
and click on the Support Tab on your units page, it will give you the option to download the user manual to your computer.
Hope this helps.
Oct 12, 2009 | Humminbird Smartcast Rf 35 Dual Display...
My Humminbird Matrix 67 shows 11.3 volts on the
Hi!
Go into the menu (press menu twice) and look for the alarms tab. There is a setting you can change for a low battery warning, make sure it is set to off or as low as you can get it. Also it may be time for a software upgrade (available at a service center)
Best of luck!
Mike
Jul 08, 2009 | Humminbird MATRIX 97 GPS Receiver
Gain failure
If you are 'testing' the unit by holding the right button and pressing power, the pmax units really don’t work with the internal test. What you are seeing in the test is what th humminbird factory computer test used to test it. That is really not intended to be used outside of the plant. If it works fine in normal mode then I would say that the unit is fine.
Best of luck!
Mike
Jun 28, 2009 | Humminbird Piranhamax 220 Fishfinder
My smartcast fish finder is only showing the word smart cast on the display
My SmartCast RF 25 was only dislaying "Waiting for Signal" called Humminbird said the problem was the RSS unit. Six month warranty.
Apr 27, 2008 | RIM BlackBerry Pearl 8100
Is it possible to make my Humminbird 787c2 to show METRIC unit instead of IMPERIAL?
hi
Did u bought Humminbird 787c2+GPS or just Humminbird 787c2 ?
If u bought Humminbird 787c2+GPS i like to know, do the built in GPS UniMAP work in australia ? i bought one myself. Thanks.
Mar 27, 2007 | Humminbird 787c2 GPS Receiver
Humminbird Smartcast Rf 35 Dual Display Wrist Sonar Logo
362 people viewed this question
Top Humminbird Sport & Outdoor - Others Experts
Are you a Humminbird Sport and Outdoor - Other Expert? Answer questions, earn points and help others
