Question about Exercise & Fitness
Belt slipping on treadmill
Belt slips on Healthrider treadmill. I tried to adjust the belt tension but still happening.
  • Anonymous Mar 16, 2014
    When walking on my spirit treadmill it feels like the belt slips
  • Anonymous Mar 27, 2014
    Seven year old treadmill. The belt is slipping randomly. How to fix this problem?
  • 83 Answers
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
    New Friend:
Three reasons my cause the belt slip:
1. The roller is small.
2. Uneven silione oil.
3. Belt is loose.
Just check them.
We are the professional belting manufacturer,any more question,can contact us.
Posted on Jun 26, 2013
Why does the belt slip forward when I run on it?
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Sep 15, 2015 | Exercise & Fitness
Belt keeps slipping on treadmill
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Adjusting the belt of the Precor 9.1
Mar 13, 2014 | Precor Exercise & Fitness
New running belt tracks to thr left
Feb 04, 2014 | Precor C962i Treadmill 220V
Walking belt alignment how to
Jan 07, 2014 | Precor Treadmill Belt 9.10, 9.2 Treadbelt...
How do I tighten drive belt on precor 956i
Jan 04, 2014 | Precor 956i Experience Series Treadmill...
Walking belt slipping
Dec 22, 2013 | Precor Exercise & Fitness
Adjust belt side
Dec 19, 2013 | Precor 9.21 Treadmill
How do you adjusting the running belt on precor 9.1 treadmill
Mar 13, 2013 | Precor Exercise & Fitness
Precor c944 treadmill belt slipping
Feb 05, 2013 | Precor C944 120 Vac Version 1 Treadmill...
Exercise & Fitness Logo
1,508 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
