Question about Campbell Hausfeld 28 - Gallon Air Compressor
Does not put enough air in tank
Compressor runs but cuts off after it puts 2 or 3 lbs. of air in tank
  • Anonymous Feb 04, 2009
    I have a husky aircompressor wl660900aj. builds preasure to 60 psi, and no more,but keeps running. Unit no more that 10 hour on it. Please help.
    Scholar:
  • 107 Answers
You either have a faulty or out of adjustment regulator.
Mike
Posted on Jan 07, 2009
The air compressor will now only pump a small amount of air. Not enough to put 12 lbs into a lawn tractor tire. Worked fine for several years. how to repair, please?
many small air compressors are made with ceramic internal parts, when they wear out there is no fixing them, one must buy another compressor
Oct 21, 2013 | Air Tools & Compressors
MY AIR TANK WILL ONLY HOLD 40 LBS OF AIR WILL NOT GO ANY HIGHER I HAD THE PRESSURE SWITCH TESTED AND ITS GOOD WHEN IT GETS UP TO 40 LBS IT STAYS RUNNING AND WILL NOT SHUT OFF MODEL FP209001 2 GAL...
If the pump is putting out 40 lbs then it is working these things are loud there must be air leaking out some where are you sure that the petcok on the bottom of the tank is closed or the blow out valve is not leaking or mabey I would say the gauge but it dosn;t shut off If the pump is putting air in that tank it eigther compresses or it comes out run your hands all around the mechine when its running there must be a leak
Nov 24, 2010 | Campbell Hausfeld 2 Gallon Air Compressor
Connecting the compressor to a tank
You left that question rather vague. Are you asking what material? or What size? I normally would run one size larger pipe size than the outlet on the tank, unless the distance is great. You would connect to the tank outlet which is usually 1/2 way up the side of the tank. Use only black iron or copper pipe, plastic pipe is not strong enough for compressed air. There is some plasic tubing rated for air, but that looks sloppy and isn't inexpensive eitehr. Also put a "FRL" between the compressor and piping (FRL=filter regulator lubricator).
Jul 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
COMPRESSOR ONLY GOES UP TO 65 LBS.
this unit should have a pressure switch that cuts the unit off and on with a adjustment to set the cut out .most switches have two adjustment screws.one of them tells the unit to kick on when the pressure is getting low.the other adjustment will raise the pressure to the desired amount.
Jun 16, 2009 | Northern Industrial 2 Hp Twin Tank...
Craftsman 3 gal ari compressor low presure
put a blower on the hose and see if air comes out
very possible there is a blockage in the hose or if you are using quick connects they may have failed
Apr 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Apr 12, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My compressor doesn't build enough pessure.
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER.
Mar 18, 2009 | Craftsman Air Tools & Compressors
Campbell Hausfeld 28 - Gallon  Air Compressor Logo
169 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
