Question about GE 26938GE1 Cordless Phone
2nd handset doesn't work
I bought this GE 900 mhz model 26938 with dual handset and the 2nd handset doesn't work. Handset one is plugged into the phone jack and it works fine. The second handset is plugged directly into the electrical outlet and it has never worked. When trying to operate the phone, the message window says "unavailable". It has been plugged in the electrical outlet for one month.
    Sniper:
  • 52 Answers
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
Posted on Jun 02, 2009
GE 21008GE2 2.4GHz Dual-Handset Cordless Telephone. Lost manual. Need to know how to access my answering machine messages from another phone out side of the house.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/21008_DOM_ES_CL_IB.pdf
The 21008GE2 is a phone, not an answering machine. It doesn't store messages that can be accessed from the phone or another phone.
If you want to access messages on an answering machine, you'll have to tell us the make and model of the answering machine.
Jul 29, 2011 | GE 21008GE2 Dual-Handset Cordless...
When removed from cradle and then dial it gives a beeping sound and does not dial or have connection sound.
First, does the base have power? Is the handset fully charged and recognized by the primary base station (for a multi-handset system)? Is the base station plugged in to a working phone line (I like to use an old corded phone for checking this - listen for dial tone first)? Is the phone cord to the base bad (try a different cord)? Does your phone work with the base plugged into another phone jack? If you can, check if the incoming phone wiring is working (there should be a box where the utility comes in that can be opened - plug in a test phone into the test jack there).
A bad jack is indoor wiring and you will be responsible for fixing it. (Depending on the faceplate, these are either multiple wires to screws or a terminal block. The screw type can be overtightened and break one wire.) If it is a problem at the utility box, your phone company should do the service.
I hope this helps.
(I've lost phone service at the box on one line of a multi-line home for unknown reasons and lost all lines due to a bad backhoe operator. Both were fixed asap by the company. A third outage only affected the dsl and was lightning strike related - damaged a noise/interference block.)
Mar 09, 2010 | GE 26921GE1 900 MHz Cordless Phone...
No dial tone
Sounds like you may have a problem with the one handset. Check to see if there is a volume control that you can turn up louder. It may only work while you have the phone in the talk mode. If that doesn't solve the problem then it sounds like the handset is bad. You may also want to plug a headset into the bad phone to see if it will work that way. Providing of course that the handset has a jack to accept a headset. Good luck.
Apr 17, 2009 | Uniden Cordless Phone
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
Handset Replacement
Did you get a replacement for your handset?
Dec 27, 2008 | Uniden Cordless Phone
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
De-registering my 2nd handset
I unplugged the battery and plugged it back in and it fixed the problem
Nov 04, 2008 | GE 28111EE2 Cordless Phone
Second phone not working.
From the manual:
VERY IMPORTANT: BOTH HANDSETS MUST BE REGISTERED TO THE
MAIN BASE BEFORE USE. After the 2nd handset has charged for 16
hours, place it on the main base station for 20 seconds, it will then
automatically register and verify its security code.
Jan 27, 2008 | GE 21008GE2 Dual-Handset Cordless...
Ge cordless model 27831 issues
you have to place the handset 2 in on the main base by 'round 20 seconds so it will be registered by the system
Apr 28, 2007 | GE 27831GE2 Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
GE 26938GE1 Cordless Phone Logo
203 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
