Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Brushes Won't Turn
The roller with the brushes won't turn and I've used the reset button without success. The vacuum has been in the cellar for several years and although the motor runs fine when I turn it on, the roller won't turn. I took the screws out of the bottom plate, but it didn't seem to want to come off very easy, so I didn't want to force it. Any thoughts on how to unfreeze my brushes?
I am having the same problem .
Posted on Feb 11, 2009
I replaced both belts on rollers after the drive belt broke and now the rollers do not spin when I try to operate it. Is there a reset button I am not seeing?
It sounds like the belts need adjusting. The instructions that came with the belts should explain how to adjust the belt tension. Additionally check for debris around the brushes. This may be the reason for the belts breaking to begin with. Without the belts on the brushes should turn freely by hand. If that doesn't do you can call Consumer Care 1-800-237-7691. Hope that helps.
Nov 14, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Why won't my brushes turn
most likely stripped gears on the end of the brushes. (beltless model?)
Nov 21, 2011 | Hoover WindTunnel V2 U8148-900 Upright...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't turn
The brushes are powered by air suction from the motor. At the heart of this complicated system are roller bearings. When one fails the system fails. This is not one of the parts that Hoover thinks is needed on it's parts site so I've haven't found a way to repair this.
Jun 28, 2011 | Hoover F7452-900 SteamVac Upright Vacuum
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Chris Jones
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
114 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
