Question about HP Pavilion dv9000z Notebook
Screen goes cloudy when turned on.
When the laptop is turned on the screen goes to a cloudy gray. It did this a couple times and then worked ok for a couple of days. Now it will only go to this cloudy blank screen. Any ideas?
  • john1701 Jan 07, 2009
    I have had this problem also. HP replaced my motherboard and it worked fine for about a month then did the same thing again. I sent it for repairs a second time and when I received it back it wouldn't even turn on. Now I am awaiting its return from a third attempt at fixing it.
    My dv9000 was out of warranty but they are repairing this issue for free. I've looked at some other forums and this seems to be the case with a number of people. There is alot of discussion about motherboard problems and graphics cards. I think your best bet would be to call HP as they would most likely repair yours for free as well, although as I said, Its taken me 3 times to send it to them, and I'm still waiting on this last one.
    Scholar:
  • 36 Answers
Xps m1530
Sounds like your video chip or your backlight. Hook up an external monitor. Does it stay on or the same results.? How long before it goes off/BLACK ???
Jul 05, 2013 | Computers & Internet
IMac screen goes black upon startup
Try a PRAM reset. Probably more than once. http://support.apple.com/kb/HT1379
Sep 30, 2012 | Apple iMac 24 inch 2.4GHz/ 1x1GB/ 320GB/...
Laptop screen white and cloudy
From your description I would expect that the LCD panel has shorted or gone open. Either way the panel needs to be replaced. Depending on the age of the laptop you may be better off getting another laptop, new or used, and just swapping out the hard drive to your drive. If you decide o do this be sure that the laptop you buy is compatible to your old drive.
Jun 08, 2017 | Computers & Internet
I have a Dell Inspiron 1545 Laptop and when I turn it on it goes to the Dell screen and then after that loads it goes to a gray screen that requests a admin password. i have tried everything to get pass...
1st try taking the cmos battery out of the motherboard remove the keyboard, palmrest then motherboard ,its a little round flat 3volt battery. take it out unplug your laptop and take your laqptop battery out and push and hold down the power button for about 10 seconds. then wait couple hours then install the cmos battery back and try to power on
May 26, 2011 | Dell Inspiron 1545 Notebook
Laptop screen purple psychedelic visual and then screen blank
Sorry to hear that you are having problems with the computer display.
Per your description, I believe the display controller was damaged by the power surge. The laptop may need replacement of the display OR use it with an external display.
Nov 06, 2009 | Computers & Internet
Laptop won't boot - gray screen
Dear user,
Your it seems that the LCD panel of your laptop is not working. and the sign of clouds is the sign of broken or screen pressed LCD. thats why the LCD did not work properly.
Please consult with qualified technician and tell him to check its LCD.
I am hopeful that you will understand my solution well.
Thanks
Sep 28, 2009 | Computers & Internet
Dv9000 screen not working just gray and cloudy
if the problem happens from start up hit f11 and try to repair/recover. also it might be stuck in the wrong mode. once you start up try pressing fn key and f5 at the same time a few minutes after start up. this may help. if not your screen maybe going out. have you done any hardware changes lately or software changes? calling hp if still under warrenty is a great way to get the problem fixed
Jul 15, 2009 | HP Pavilion dv9000z Notebook
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Screen turns grey
It could be the computer is trying to save power, by turning off the screen, go into the control panel, and find the power option, and look through the tabs for an option to turn off screen this might work
Jan 09, 2008 | Compaq Presario M2000 Notebook
Toshiba a105 screen goes blank
Sounds like GPU failure. unfortunately its nigh on impossible to replace without replacing the whole board which can be expensive. I saw a few on ebay for around £120.
Aug 14, 2007 | Toshiba Satellite A105-S4004 Notebook
HP Pavilion dv9000z Notebook Logo
1,304 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
