Question about Canon PIXMA MP180 All-In-One InkJet Printer
Says that there is a paper jam but no paper is in printer
Alarm E 3 keepps showing up
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
Hi, "ALARM" appear on my
Hi Good day!! Maybe you have a paper jam that cause your printer to alarm.
To clear a rear-feed paper jam:
1. Turn off printer
2. Turn platen knob to back paper out of printer. Remove any ripped pieces of paper.
3. Reload paper, turn printer back on and press FF/LOAD button.
If your paper keeps jamming the chances are excellent that you have bits of paper stuck in the paper in the paper path. To eliminate this problem:
1. Turn off printer.
2. Use platen knob to back paper out of printer.
3. Remove the paper separator.
Thank you for using fixYa
Don't forget to vote thanks!!
Nov 03, 2010 | Oki Electric Industry MICROLINE 791 Matrix...
It keepps saying E2 when I try to copy
E error refers to paper jam...
Make sure there is no paper jam..
try again and hope it works for you.
Thanks..
Sep 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Red alarm wording showing, what does that mean
The Alarm light will come on if:
1) The printer is out of paper.
2) The paper is jammed.
3) The paper is too far to the right. (The paper must cover the small groove on the left side of the rubber platen.)
Thanks for using Fixya.
Aug 27, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX300 Paper Jam alarm
hi I'm 30 eyars old from sudanes girl ilove sexy girl&woman
May 31, 2009 | Canon MX300 Office All-In-One Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam
Just for sharing,
Yesterday i got same phenomenom. After i check , i found the root couse came from, printer head (PG-40) is hit foreign part in the left side when printer is initialize. So the home posistion of head become shift to right. So when the head move to right in parking area, become hit stopper of waste ink platen, that impact to mechanism of paper feeder.
After the foreign part is removed, my printer can work normally.
Sep 26, 2007 | Canon PIXMA iP1600 Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
old marine
old marine
