Canon copier - toner is not set
Error flashing - on screen is say toner is not set insert toner - we have done that a couple of times
  • copysavage May 11, 2010
    what model is the machine? are you using canon genuine toner?
Don't know what we did but it's working now
Posted on Jan 08, 2009
Error set paper again set toner again
after having opened the top and pulled it out. I recommend examining whether there is any evidence of loose toner in the machine at this point.Push the toner cartridge in to make sure it is properly seated.Then close the toner cover.Then close the scanner.
let me know whether this helps the problem any, or changes the machine's status.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon Office Equipment & Supplies
Showing toner error after installing NON Canon toner cartridge. Will not clear.
Yes...Duct tape works wonders. Most of these printer cartridge
have built in chips that match to the printers they were designed for. This is the manufactures way of saying "Hey, we practically gave away our printers, so now you have to pay outrageous prices for the ink"!!! Place the tape on the light and enjoy the savings ;-)
Nov 08, 2013 | Canon Laser imageCLASS MF4890dw Wireless...
Imagerunner c5035 - I inserted the wrong color toner cartridge in our Canon ImageRUNNER C5035 and cannot open the toner cartridgde door to insert the correct color (black). All our copies are coming out...
Press Settings/Reg button
#1-#7 same time
then #3-#9 same time
then Settings/ Reg again ( this needs to be done quickly)
This will bring you to a blue screen with a bunch of numbers on it. Navigate to #69 and select.
This will bring up a screen with you CMYK cartridge choices. Select which you want to remove, then select OK in bottom right.
To exit this screen just hit reset twice and you will be back in normal operation mode.
Sep 20, 2013 | Canon imageRUNNER ADVANCE C5035
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
Canon imagerunner error code E000024-0001. All I did was replace the empty toner cartridge!
first try to pull out and place it back in toner station, it maybe needs more time to replanish the toner few more times.
By the book, its toner sensor error. did you use force to replace toner? maybe you broke it, or damadged the toner holder and toner isn recognized.
The tube should rotate, when everything is OK,so, open toner cover, insert toner tube, lock it, put piece of paper in sensor hole ( the hole in wich goes plastic nose of toner section door ).
Hope that helped!
Jul 22, 2010 | Canon IMAGERUNNER 2230 Copier
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
May 06, 2010 | Canon ImageRunner 3320N Copier
E020 IN CANON 6050
This an error for out of toner. Make sure there is toner in the hopper. Do this by pushing down the hooked shaped clips on top of the hopper and at the same time move the slide to the right. Using a flashlight look into the hopper see if there is toner. There was also a mod kit for cleaning the toner sensor that should have been done. Return the slide back to normal position. Add toner if needed. If there is toner you will have to remove the developer unit , access from the bypass door. Unscrew the top of the developer unit, look to make sure that there is toner inside. Return to proper position when through. You will also have to reset the error after toner checks ( service mode ). Do this by inserting a straightend paper clip into hole located below control panel on left side. You should see a $ on control panel. Press * 4 *. Look for " ERROR ". Use arrows on screen to move through the different screens. Touch screen on error to highlight. Press OK. Turn off and back on main power switch ( lower right side ). To refill developer unit if needed is to go into service mode and *4* and look for INSTALL. Look for TONER-S. highlight and press OK. Copier will run and time down until developer is filled correctly. Reset key serveral times and copier should be OK. Run several 20 copy sets to test that toner will hold.
Dec 14, 2009 | Canon NP 6050 Copier
Toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Nov 06, 2007 | Canon imageRUNNER 400S Copier
76 people viewed this question
