Question about Zebra LP 2844 Thermal Printer
I couldn't stay connected with Scott long enough to tell him anything
Not sure how to reconnect with him Is it possible for you to assist him or get someone that can. I have to go on a business trip and will have limited connectivity to FIXYA
Zebra 105SL
Rating: 0%, 0 votes
Rank: Apprentice
By scott_rasmus
Session Date: Jan 06, 2009
The barcode above produced when scanned: 99700160000001901021203000missing DJS Zebra embedded characters in the string should of produced99700160DJS000001901021203000 can you tell me why when sending thefollowing string: >;997000160>7DJS>500000190102120300 in the^BCN (128 Barcode) that I can not get the DJS to be printed out in theBarcode? Zebra Documentation invocation commands: >; -- start subsetcode C >7 -- switch to subset code A >5 -- switch to subset code C
scott_rasmus: Need to chat with you. How do I get my session back?
  • Zebra Master
  • 19,396 Answers
Hi there, unfortunately when a chat re-connects it will be taken by te first expert responding, I don't think there is any way to connect your chat.
If your chat was being successful, try contacting the user by answering his free question, or adding a comment to the chat thread on your profile.
You can also contact Lauren, lauren@fixya.com , but I think there is not much she can do either.
Posted on Jan 06, 2009
Just replaced thermopile generator and pilot will not stay lit
Check the new thermopile with a millivolt meter and make sure it has the correct output not connected to the gas valve.If it does,then the gas valve is defective.Make sure to test ONLY the thermopile.If it does not generate enough millivolts the gas valve will not open.If the piliot is dirty it will not generate enough heat for the thermopile.Make sure you have a good,strong,blue flame at the pilot.You said the piliot will not stay lit?If not then start by blowing air back through the piliot where the flame comes out with compressed air.hopefully that will clean it well enough.If not you may have to take the pilot tubing loose from the valve and use compressed air to clean it.Make sure when you reconnect the tubing to the valve USE FINGERS ONLY to start tyubing or you may crossthread the tubing....and thats NOT a good thing.Good Luck.
Jan 16, 2015 | Williams Wall Heaters: 35,000 Btu/hr...
I have a 2003 GMC YUKON that I'm having problems with my ABS warning light comes on and stays on,is there a diagram showing the points of connections
check make sure you reconnect the wheel speed sensor built in the wheel bearing assembly make sure you reconnect wheel speed sensor connector or look make sure no wires and connector wont damaged.
Nov 24, 2012 | Cars & Trucks
After I defrosted my refrigerator it will not cool after it's been turned on. I seem to have enough freon and compressor looks okay in back of the unit. I can't tell on this particular unit if...
Unplug the refrigerator and wait at least five minutes before reconnecting the power. A temporary fault could be preventing the internal computer from operating the refrigerator correctly. Disconnecting the power forces the computer to reset itself when the power returns. Plugging your refrigerator back in before three minutes has elapsed could cause the refrigerator not to start.
hope this helps let us know.
Dec 31, 2017 | Avanti Refrigerators
Won't start. No spark. Suspect oil alert.Only ran twice out of box. Had to buy another generator as I couldn,t take the time to fiddle. 10 or 15 yrs. ago.
That is easy enough to tell if it is the oil alert malfunctioning by disconnecting the wire that goes to the oil alert and making sure the wire is not grounded and check for spark.
Mar 11, 2011 | Electronics - Others
I have A PS3 I cant reconnect to the internet now I am getting this code 800E026 can you tell me what it means
Please provide more detail information as to your issue.
there is not enough here to give a complete solution to your issue.
try resetting the router and restart the PS3
You question will need more information for us to further assist you.
May 20, 2010 | Computers & Internet
Sansa View - reconnects over and over
Unfortunately, the two things you already tried are the only troubleshooting options available. There is either a loose connection inside the player or possibly you have a bad USB cable. If the cable is fine, the unit needs to be repaired/exchanged through the manufacturer.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Apr 24, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
1997 Toyota Camry Lost All Battery Power
I would check your main battery terminals to make sure they are not loose. Sometimes, even when you have reconnected them properly they may not be tight enough to make a good electrical connections...I have seen it a million times and I have also been a victim myself :) If you shake them and they swivel at all that may be your problem. Sometimes another way to tell is if you can move them around and the car starts one time, then later that day or sometime down the road the car wont start again this is a sign that the connection is your problem. You should definately try this first, then go from there.
Feb 11, 2009 | 1997 Toyota Camry
Crest Audio CPX-900 Amp
check the input signal.switch the cables and see if that changes anything.also check the back of the amp for filters.make sure that they are set the same way.check cables on source coming in to amp.ie-quarters to rca's or rca's to xlr's.make sure amp is not set to parallel inputs or bridged mono.
Jun 25, 2008 | Crest Audio CPX-900 Amplifier
Connects and Disconnects often
I think Gryph that you may want to try another usb port, but if that dosn't work then im not sure
Mar 14, 2008 | Creative Labs Zen Digital Media Player
Reset button
Without owning one , I checked the manual and, sure enough, there's no circuit breaker shown. I mailed tech support. Meantime check where the AC comes in and the fuse holder ( unplugged) and see if you can find anything.
Jan 03, 2008 | Pyle PZR-1000 Amplifier
Zebra LP 2844 Thermal Printer Logo
95 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
