Question about KitchenAid KESC307 Electric Kitchen Range
Kitchenaid glass top electric range
I have an error message on my range that says stuck key err F2E0? Does anyone know how to fix this problem or do I need to have a repair serviceman?
  • 5 more comments
  • Anonymous Nov 25, 2007
    Same problem...Stuck key err F2E0. Argh.
  • Anonymous Dec 12, 2007
    My oven is stuck. It says stuck key, error F2E0 on the display. I can't get the oven to shut off or turn on. I have made several things in the oven tonight. I had turned it off an hour or so before I decided to use it again. I pressed bake and plugged in the temp. 425 degrees. I thought it was preheating and then it just went crazy. The display started switching from one temp to another, beeping each time. I tried turning it off with no luck. I tried turning it on and it wouldn't do that either. My oven is just turned 2 years old. I had an old piece of junk that NEVER gave me a problem. I bought my kitchen aid when I redid my kitchen. I also bought a Kitchen aid dishwasher which has needed service. Never again. If anyone knows how to fix, please help!! I need to make food for my children's classrooms. It is the holidays and I am doomed!!
  • Anonymous Jan 26, 2008
    Same Problem. Initially says remove probe or enter probe temperature. Then gets to this error
  • rashmash Mar 06, 2008
    I have the same problem, stuck key err F2E0.
    I don't know where is the sensor even, so can any one please tell me in which part of oven this sensor is placed..I mean under the button control panel or inside the oven?
  • mbpflyer Apr 12, 2008
    Over shows (enter probe temp or remove probe) with no temp probe installed. Is there a way to reset. Thanks Mark
  • Anonymous Jun 19, 2008
    I bought my range in January 2007 and I have the same problem with error code F2E0 - Stuck Key. Does anyone have a fix for this error? I tried unplugging the range but I'm getting the same error.
  • Anonymous Mar 16, 2014
    remove back
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
Posted on Mar 06, 2008
The clue to the open oven was the winner! I closed the oven door but could not clear the error by the keyboard, so I cycled the circuit breakers to reset the oven. It worked with the only downside of having to reset the programs... starting with the time.
Posted on Oct 13, 2008
That error code is for the "open oven sensor". You probably just need a new sensor.
Posted on Jun 07, 2007
I have a Whirlpool Gold 18 months old. I was running the self-clean cycle (3 time I run it since I've had it). Half-way through, it starts beeping AND this message appears: Stuck Key F2E0
What does it mean? Sears brushed me off saying the 1 year warranty is up. We can help you out by sending a technician and charging to tell me what the code means! Why do I keep buying from Sears!
Assistance would be appreciated.
Eric
enleclair@sympatico.ca
Posted on Oct 25, 2008
  • the moots Oct 23, 2010
    I have a Kitchen Aid with touch oven controls and i just kept running my fingers over all the controls (the oven was beeping like crazy) then all of a sudden the time appeared and all was well - not very technical, but i assume that it was like rebooting the system! Good luck.
Eric
Kitchenaid Ykers807ss00 error display f2e0
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 10, 2013 | Kitchen Ranges
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
How to fix F2E0 error on Kitchenaid stove ?
Your electronic range control clock has gone out on this unit. You can contact us at accurate-appliance-service.com for all your parts. We can get the correct part out to you right away.
We hope this answers your question and the best of luck to you.
Oct 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
Getting an error code on the display F2E0 (stuck key). When I was wiping off the display. Is there a way to reset this?
Sometimes you can get lucky by pressing all keys at random several times each. If that does not work you will have to replace the keypad.
Oct 09, 2009 | KitchenAid KEBC101 Electric Single Oven
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
3,819 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
