Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Error message -E2
HELP! My Hobart LX18 dishwasher displays error message -E2
Can you help me solve my problem?
Thank you
Pat
Waterfront Coffee Company
101 Main Street
Edmonds WA 98020
425-670-1400
  • facilitie306 Jan 12, 2009
    I have a Hobart LXiH with the same E2 error code.
    James Barnes
    Facilities Manager
    Houston SPCA
Hi jim just push off button then on button then off again. this will drain off then go to restart mode. hope this helps.
Posted on Feb 06, 2009
What to do when you get an error message E2?
E2 = No or slow fill.
Water did not reach the float during a fill within 2.5 minutes.
Press OFF, wait 5seconds and press. ON.
Make sure water suplly valv is open.
Apr 07, 2016 | Hobart AM15T Dishwasher
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Hobart lx18 Dishwasher wont fill up
Frank,does the sump probe (the one underneath the screen) look good?It should have at least one quarter inch of metal.I have seen these break and its hard to tell but the info your describing sounds like that probe is bad or the control board.I'm a hobart tech and can help you troubleshoot,let me know----Tony
Nov 21, 2009 | Hobart Dishwashers
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature Problem
Whats the model?lxih,lx30h,lx18,lx40?What temps are low,wash or rinse?Im a hobart tech and service these units.Let me know.
Jan 19, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Dec 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX18 E4 Error. Where can I get a manual?
this is asensor error unit not filling fast enough or loose connection
Nov 25, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart lx18
$0. Clean the probes. Two in back right corner. Two under the front screen. Use a green scrubby.
If the problem persists, check where the water comes into the machine. There is a screen on the hose that clogs up and starves the machine for water.
Apr 12, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
738 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
