Question about Aja Video Systems Io LA (IOLA) Video Capture
Aja io la converter box not responsive.  trying to set up betacamsp uvw-1800 for conversion to digital signal via aja to powermac G5 single processor on OS X 10.4.11.  Need help fast!
Can a apple powermac g5 with a 2.5 processor with a 1TB solid state drive run OS 10.11 ?
No.
The highest OS a G5 can run is 10.5
All OS versions after that are for Intel processors only
May 26, 2017 | Apple Computers & Internet
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
PowerMac G5 with dual 2.7 processors powers on but no video
There are seven diagnostic LEDs near the memory banks of this model: six in a tight line between the edge of the logic board and DIMM bank 1, and the seventh just underneath DIMM bank 1 and slightly more inboard. Please tell me which of these LEDs are on and I will tell you what they mean.
Sep 25, 2009 | Apple Power Mac G5 Desktop
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
How to replace the power supply on a powermac G5
I would be very cautious doing this, if you are not an Apple tech. You can damage the connector for the G5 Processors, and render the machine un-usable.
You have to remove the RAM and Processor, then remove the two power connectors that connect from the power supply to the logic board. On the bottom, underside of the chassis, there are four screws. Remove them, then you can tilt the power supply out of the bottom of the unit.
Replacement, is just the reverse.
Apr 17, 2009 | Apple Power Mac G5
Power Supply blew up, need to replace
Hi, Sorry to hear you are having problems,
Here is a very useful website:
http://g5.bhmm.net/
it will show you how to take apart a Powermac G5 step by step.
Mar 16, 2009 | Apple PowerMac G5 Dual Mac Desktop
Connect internet via ethernet
to use dhcp with several computers, you need to have a box that allows the dhcp mode and which is configure to goes on
Jan 17, 2009 | Apple Power Mac G5 Desktop
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Conversion box
this set is a standard 4:3 projection, so yes, to receive digital, you will need a converter.
Jun 19, 2008 | Philips 60P8341 60" Rear Projection...
Aja Video Systems Io LA (IOLA) Video Capture Logo
132 people viewed this question
Top Aja Video Systems Televison & Video Experts
Are you an Aja Video Systems Televison and Video Expert? Answer questions, earn points and help others
