Question about HP LaserJet 4700 Printer
Streaking problem on print out
The print out is fine for the first 10-20 sheets then begins to streak on the right hand side of the sheet. I printed out the four color sheets through the diagnostic and all look fine. I also cleaned everything possible. Any thoughts?
    Genius:
  • 2,120 Answers
You have a bad drum cleaning blade. There is no way to replace it without buying a new toner cartridge.
Posted on Jan 07, 2009
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
Jan 21, 2011 | HP LaserJet 4050 Printer
Canon 3220 toner streaking/ghost image
It might be afixing problem, but did you try to replace ITB cleaning blade?Its hard to say without seeing a copy/ test sheet
Jan 13, 2010 | Canon Office Equipment & Supplies
When printing 2 sided sheets our machine puts dark gray streaks on the paper after printing more than 6 pages. The streaks continually get larger until they cover most of the page.
When you are printing 2 sided sheets the reason you are getting streaks, is your first sided not dry yet. I know it is a laser printer, even laser you have waite a bit.
Dec 03, 2009 | Xerox Phaser 7700 Laser Printer
I have fading on the right hand side. Printer Dell 3100CN
Dell printers are junk. But you have put a lot of money into this thing. Check the alignment of the black drum, could be that something is keeping if off track a little bit.
May 26, 2009 | Dell 3100cn Laser Printer
Streaks in my pictures
You can clean the print head by using the following procedure from the troubleshooting section of the manual:
Take paper out of the printer
Take a single sheet and put it back in - upside down (i.e. shiny side down).
Close the door and wait for the sheet to eject.
Put all the paper back into the printer in the correct orientation (shiny side up), close the lid and print again.
I've discovered even better results by keeping the special blue sheet that comes with each paper pack. I run the special sheet through before I'm about to use the printer for the first time (after not using it for a few days), and also after every three prints. The result is much better printouts for me. The special blue sheet cleans and calibrates the print head. Just put the blue sheet in the paper tray at the bottom of the stack with the bar code facing down and close the lid. It will automatically eject.
May 11, 2009 | Polaroid PoGo Digital Photo Printer
I changed the ink in my canon ip1800 and now it the me the print head need alignment and i don't know how to do it.Can you help
1. For Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes
2. Select your printer model name icon.
-> Printers and Faxes.
3.Open the File menu and select Printing Preferences.
The printer driver setup window appears.
4.Click Print Head Alignment on the Maintenance tab.
A message appears.
5.Set the paper thickness lever to the left, and load a sheet of A4 or Letter size plain paper into the auto sheet feeder.
6.Follow the instruction in the message.
7.The Print Head Alignment dialog box opens.
Select the numbers of the patterns with the least amount of streaking in the associated boxes.
Clicking the patterns with the least amount of streaking in the preview window, will automatically set their numbers in the associated boxes.
8.When you have entered all the necessary values, click OK
And that should do the trick for you.
Sean
Feb 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
HP LaserJet 4700 Printer Logo
252 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
