Question about Akai CF2791 27" TV
Is Model CFT 2791 DTV compatible?
My CFT 2791 AKAI was Manufactured July '02. I use an antenna only and was wondering if that model is analog only or has digital capability that would allow me to avoid having to purchase the digital conversion box.
Thank you
5 Suggested Answers
  • 749 Answers
SOURCE: Am not able to identify the TV's video input channel for my AKAI CFT 2791
yellow input for video
red and white correspond to audio
Posted on Dec 06, 2007
  • 7 Answers
SOURCE: I have a AKAI CFTD
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Posted on Dec 04, 2008
  • 23 Answers
SOURCE: need set up codes for cft 2790 akai tv
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Posted on Feb 18, 2010
www_yoges685
SOURCE: akai cft2726 tv
www.akaiservicecod.com
Posted on Apr 09, 2012
Mintek DTV-260
The Mintek DTV-260 only has a NTSC (analog) tuner. You will need to connect your RCA antenna to a digital to analog converter box to watch TV over the air. Then connect the output of the converter box to your TV.
The common converter boxes are limited to SD output. You might be able to find an HD converter box online. (With the standard converter box, the available outputs are coaxial and composite video.) The DTV-260 has a composite video port; alternatively set the TV to channel 3 or 4 and use the coaxial (RF) input on the TV.
There may be a low-power station that still broadcasts in analog. However these are rare. You will need to switch from CATV to OTA (Air) to check for one of these stations. Analog Cable has different parameters than scanning for over the air signals.
I hope this helps.
Mar 04, 2014 | Mintek Televison & Video
Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Aug 28, 2009 | AOpen Televison & Video
No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
Feb 18, 2009 | Polaroid FLM-2632 Television
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Does a CT-27614A need a digital converter for antenna?
I hope this soultion is helpful.
Feb 12, 2009 | Panasonic Televison & Video
Conversion to DTV from analog
IF YOUR UNIT HAS AN ATSC TUNER THEN IT IS HD READY. SEE YOUR OWNERS MANUEL. HOOK THE ANTENNA TO THE RF (ANTENNA) CONNECTOR .GO INTO THE MENU AND AUTO PROGRAM CHANNELS. GO TO CHANNEL 5 AND SEE IF YOU HAVE 5.1 OR 5.2 IF SO YOUR DONE.
Jan 30, 2009 | Akai LCT2721AD 27 in. LCD Television
Phillips magnavox smart plus Model TP3284C101
if there is a DTV label on it , then it is digital .check the manual
digital would have the following : atsc ,hdtv ,digital tuner ,dtv
Jan 02, 2009 | Philips TP3284C 32" TV
Digital tuner?
Good question, Mike. I wondered about my fs210 model, too, and I found the answer at a Sony tech-support site.
1. Go to: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
2. Enter your TV's model number, which, in this case, is: kv-32fs100 (and then click on Continue).
3. At the resulting page, under "Support by Type" in the left margin, click on "News & Alerts."
4. At the next page, click on: 04/02/2008: Critical: Is my Sony® television ready for the Digital TV (DTV) transition?
5. Your TV and mine are analog, but scroll down the page mentioned in #4, above, to see all of your options.
Consumers can determine whether any Sony TV is digital, just by entering the model number and following the steps listed above. ~ Kind regards, Gilda M. (replied 1/23/09)
Nov 11, 2008 | Sony FD Trinitron WEGA KV-32FS16 32" TV
I need help tv lcd akai model lct2785ta
You do know that this model TV takes about 5-10 seconds to come on after you press the on button, right?
Press it once to get the green LED, then wait. If it doesn't display the blue AKAI splash screen within 15 seconds, the TV is not working as it should.
Also remember that this model has two RF input jacks. As seen from the back of the TV, the jack on the far right is the one to use for analog TV, analog cable, coax out to TV from a cable box, or rf out from a vcr.
Don't use the one on the far left. It is for input to the ATSC OTA DTV tuner only.
Most likely there is a real problem with your TV, but in the video, you are pressing the on/off button in rapid succession. That will never work with this model.
Jul 12, 2008 | Akai LCT2785TA 27 in. LCD Television
Dec 06, 2007 | Akai CF2791 27" TV
Akai CF2791 27" TV Logo
56 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
