Question about Lakewood 200I Floor / Box Fan
What if i cant figure out a way to get the grill or the blades off of my fan? What would you recomend.
The fan blade just pulls off. I have a Lakewood 200/1PG and my grills are installed with phillip head screws.
Posted on Jun 03, 2007
Broken grill Panels
Pls try here and look for an authorized parts distributor near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lakewood 200I Floor / Box Fan
My lakewood fan is making noise when on
Have you tried using a air compressor to blow out any dust around motor?
Jul 25, 2012 | Lakewood 200I Floor / Box Fan
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Switch broken
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Jul 10, 2010 | Lakewood 200I Floor / Box Fan
How to stop squeaking noise
usually these units have very inexpensive sleeve bearings that require little maintenance. Have you tried squirting a little WD-40 on the bearings?
May 14, 2010 | Lakewood 200I Floor / Box Fan
Need feet for 20" box fan
you can purchase the feet at lasko.com go to there parts dept. i think i paid 2.00 plus s+h.
Oct 16, 2007 | Lakewood 200I Floor / Box Fan
My Lakewood box fan fell over and stopped working
As the box fan is a simple electronic, I would take the fan apart and check the solder points. If one has broken loose or is cracked, simply re-solder the point. Test it and try again. Another suggestion would be to go to your local hardware store and find some appropriate L-brackets to secure the fan to the sill while still maintaining the ability to remove it and close the window. A little human ingenuity can probably outsmart a cat. ;)
Jun 27, 2007 | Lakewood 200I Floor / Box Fan
Probably requires cleaning- take the grille off, pull the blade free (most pull straight out- some have a pin/socket deal right behind the blades that need to be removed first) and clean out any gunk you may find inside. Be sure to unplug it first. before replacing the blade, turn the shaft with your hands to see how it moves; you might want to grease it with an electricity friendly lube of your choice. If it's still hard to turn, it may just be this fans time; box fans are cheap, and made cheap, and the wear-and-tear adds up.
May 23, 2007 | Lakewood 200I Floor / Box Fan
Lakewood 200I Floor / Box Fan Logo
406 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
