Question about Sanyo DS31590 31" TV
Ds31590 My husband pushed a button on a univeral remote now tv is stuck on video I have pushed every button but it will not work The menu key only works to select langauage and to set picture color. please help
  • 3 more comments
  • lavonda Nov 12, 2007
    I have a universal remote and now my sanyo ds32224 is stuck in video 1 mode. I do not have a reset button if I do I dont know where it is located. I use the menu key on the tv but it will only let me can picture size etc. it will not let me chaneel channel setup antenne and anything else,. How can I fix this proble I have a rca universal remote.
  • grandmanancy Nov 21, 2007
    We also have the same problem. The remote to our Sanyo TV quit working so we got a universal remote.We were watching a movie on DVD so the TV had to be changed to Video 1. While watching my grandson removed the batteries to the remote and it lost it's memory. The batteries were replaced very quickly but it was still too late. Can't program the remote by channeling up because it can only be changed by pressing input.
  • smcke8897 Dec 15, 2007
    My screen is blue and says video. I cannot get it out of this mode. Is there a reset button on my tv somewhere? My model number is DS31590.
    My tv is stuck on video, I have a blue screen that says video. Is there a reset button on my tv somehwere? How do I reset my tv?
  • Anonymous Dec 27, 2007
    describe the steps you've already taken to tryto resolve the problem
I recently switched from direct tv to cox communications. My tv is stuck on the incorrect input and my remote works perfectly except the input button and the menu button. I tried a different univeral...
Check For Sticky Button On The TV Set Possibility Issue with your Command Panel Press any individual button and check carefuly for Sticky button If not Some TV set got Child Protecton lock on it check if your Signal from the TV set it On Remote Mode .
Sep 22, 2010 | Televison & Video
Lost the remote and need to change from tv to video
try going through the menu keys and if this does not work try changing channels.
Feb 20, 2010 | Sanyo DS31590 31" TV
Can't change channel from video 1
You might need the remote to change from video to tuner. Try buying a cheap univeral remote from Radio Shack.
Mar 16, 2009 | Televison & Video
TV stuck on Video
I had this problem, I replaced the remote and it works now
Feb 27, 2009 | Sanyo DS31590 31" TV
All Ihaveis blue screen
You need to change the source (original remote) or the input (univeral remote). It needs to be in TV mode - not video.
Aug 30, 2008 | Sanyo DS31520 31" TV
Tv stuck on video
Try with the channel up/down on the TV or look inside the configuration menu, if your set has one.
Feb 15, 2008 | Emerson EWF2004 20" TV
Sanyo DS31590 31" TV Can I get the tv to go into tv/video mode without a remote but from the tv menu directly?
Nope. Remote control is required... However some universal remotes come with this button available in the preprogrammed code. I had a cheap GE universal remote that I used to replace the original when my 2 year old smashed it. I now have a sony universal remote and it's default code (one of them) for Sanyo tv's also works for the video/input button.
Dec 19, 2007 | Sanyo DS31590 31" TV
Whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Dec 09, 2007 | Sanyo DS31590 31" TV
Ds31590
njdb,
Look on the remote for keys that are labled tv/vcr or source or input... In fact, if you go to the front of the unit - that's a Sanyo right - find the grouping of buttons that change the channel, volume etc.. There should be a button marked source or input there.. Press it as many times as it takes to get back to the input source your cable is on...
If you have any problems let me know...
Bill
Nov 24, 2007 | Televison & Video
Tv is stuck in video mode
The best thing to do is get an original replacement remote and then you will absolutely be able to enter the menu and perform the autoprogram.
Aug 23, 2007 | Sanyo DS27820 27" TV
Sanyo DS31590 31" TV Logo
203 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
