Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Frig want get cold anymore
Turn frig off to clean when i turned it back on it wouldn't get cold
  • Ken Bledsoe May 11, 2010
    Do you still have a problem?
Check the relay button might have to be replace it happening to me
Posted on Jan 12, 2009
I just bought an used washing machine AEG lavamat 66815. When plugging it in standing on the floor there was no problem. It washed. Though the waterpipe sounded like it took in air. After the washed we...
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 13, 2011 | Washing Machines
Model# LRSC26925TT freezer and fridge wont get cold enough to maintan food for more than a day or two. freezer doesn't make ice either anymore.
sounds like the fan motor in the freezer is not working is it running ? if not turn off frig.let it defrost manually, open doors. find the motor. see if you can turn it.. if it turns. restart frig .see if it starts. if not. new fan motor is needed.good luck
Aug 21, 2010 | LG Refrigerators
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
GSS220 side by side refrig does not defrost and no longer cold
the frig is cold by the air for the freezer so if it all ice insinde no air can pass to the frig 1 turn off you frig ,, yes it not fun but you will reset the frig ( more that 3 hour )
meanwile , take out the ice of you freezer ,lower you temperature in the freezer and restart
if it do that a other time , it easy it you temperature detecter it is broken .. some you need to change it
Jun 07, 2009 | GE Refrigerators
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Frig just not Cold
you might have had freon leak out from it sitting unplugged how long were you gone ? plus you need to wait atleast 30 minutes when you unplug your refigerator then plug it back in you cannot keep plugging it on and off it will burn up the compressor / relay overload
Aug 28, 2007 | Kenmore 50522 / 50524 Side by Side...
FRIG AFD2535DES FRENCH DOOR BOTTOM FREEZER
Is your freezer fan blowing when the ref. is running, should feel air coming out the vent then,,,when running.
Aug 27, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
