Question about Uniden Cordless Phone
I need to be able to change my answering message of my bussiness from my home phone number
  • melissarsaun Jan 06, 2009
    anyone know how to do this
  • 686 Answers
If your base has a "menu" button on it try going through your menu and see what it does for you. Normaly in your menu you will have this option of changing your message onthe first push of the menu button. And by the way uniden in my opinion is not that good. They lure you with looks and low cost yet poor quality.
Posted on Jan 08, 2009
How do i retrieve messages from my home phone to my cell phone?I am out of town.
did you set a password in the setup menu for the vtech
let it ring then put in the code
May 03, 2015 | Vtech 5.8GHz Cordless Phone with Digital...
How do I set the number of times phone ring before the machine take the message?
Press and hold the SET button to enter the change mode. After the time and date you can change the rings to answer.
Full details are in the "Changing the Settings" section of the manual (page 9). If you need the manual, you can download it at
http://www.home-electronics.net/ge/pc/IB/29869GE2_IB.pdf
Jun 12, 2011 | GE 29869GE2 Digital Answering Machine
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
I need to change my answering machine voice message.....how do I do that? Also, this is our number for our business and our home. Is there a way we can separate incoming messages. ie: to leave a...
The 29897 has only one mailbox, so you can't use it to separate messages.
To record an outgoing message, hold down the GREETING button. Record your message at the tone. Release the GREETING button when done.
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
Mar 30, 2011 | GE 29897GE1 Corded Phone
How do I tell my 2820 to prepare to receive an incoming fax? My phone line and my fax line are the same number. It continues to ring but the fax machine is not answering. I have also turned the answering...
To have the machine answer faxes and record voice messages unattended change the answering mode to message centre. If you are home and pick up the phone , but it is a fax, not a phone call push *91 on the phone you answered on, and hang-up the phone. the fax machine will tyhen start receiving.
Dec 27, 2010 | Brother IntelliFax-2820 Laser Fax
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
Command Function
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Retrieve messages
To connect with your answering system:
1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
Apr 01, 2008 | AT&T 1818 Corded Phone
Uniden Cordless Phone Logo
21 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
