Question about Goodman GMS90703BXA Heater
3 flash code pressure switch ok 2yellow wires at board con seam
To be problem wonder if it is board or wireing harness or if this problem has been freak'
    Problem Solver:
  • 4 Answers
Are you sure the vent is not blocked?
Posted on Jan 06, 2009
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Frigidaire Affinity washer (LAFW3511KW0) with an E41 error. I have unplugged to reset (no change), checked the stricker (fine), removed outer seal and disconnected and reattached (I also received an E41...
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Aug 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
I bought a 1998 mitsubishi eclipse and the check engine light came on we hooked up the machine to diagnos it and we got 2 codes po700 and p1784 . we are wondering what the codes mean and how to fix the...
DTC 1784: LOW-REVERSE PRESSURE SWITCH
1.Remove transaxle relay from connector. Turn ignition on. Install scan tool and observe low-reverse pressure switch condition. Apply battery voltage to transaxle relay connector terminal No. 8. If low-reverse pressure switch stays off, go to next step. If low-reverse pressure switch turns on, go to step 4 .
2.Raise vehicle enough to allow drive wheels to spin freely. Test low-reverse clutch hydraulic pressure. See HYDRAULIC PRESSURE TESTS under TESTING. If low-reverse clutch pressure test is not within specification, internal transaxle failure exists. If low-reverse clutch pressure test is within specification, observe scan tool.
3.If low-reverse pressure switch turns on, trouble code is intermittent. Check wire harnesses and connectors for damage or poor connection. If low-reverse pressure switch does not turn on, replace solenoid and pressure switch assembly. Recheck trouble codes. If trouble code resets, replace TCM.
4.Check and repair wiring harness between transaxle relay connector and solenoid and pressure switch assembly connector. If wiring harness is okay, check wire between TCM connector terminal No. 10 and solenoid and pressure switch assembly.
5.If wire between TCM connector terminal No. 10 and solenoid and pressure switch assembly is okay, check TCM and solenoid and pressure switch assembly connectors. Repair connectors as necessary. If connectors are okay, recheck trouble codes. If trouble code resets, replace solenoid and pressure switch assembly. Recheck trouble codes. If trouble code resets, replace TCM.
P0700-The Transmission Control Module (TCM) monitors the malfunction of sensors and actuators relating to transmission control. When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transmission controls.
I would try disconnecting he battery and letting it sit for 5 minutes, then hook it back up to see if they return-the 700 code is probably related to the 1784 code, that seems to be your main issue.
Jun 06, 2011 | 1998 Mitsubishi Eclipse
F32
The F32 error code indicates a water level pressure switch failure. This is normally caused by wiring connection problem or a failed pressure switch. If you are able to unplug the washer and remove the top panel, you can check the wiring connections between the control board and the water level pressure switch. To remove the top panel (with the washer unplugged), take out the screws at the very back of the top panel and slide the panel back and then pick it up and remove it from the top of the washer. The pressure switch is on the top of the right side panel toward the back of the washer.
If the wire harness connection between the pressure switch and the control board is okay, then you will probably need to replace the pressure switch to correct this problem. The part number for the pressure switch is 8181695. You can order this part from the Sears PartsDirect website www.searspartsdirect.com .
The F28 error code indicates a communication error between the main control board and the motor control board at the bottom of the washer by the drive motor. A loose wiring harness connection can cause this problem. It can also be caused by a failed motor control board, a bad drive motor or a defective main control board. You may be able to check the wiring harness connection to the motor control board by unplugging the washer and removing the bottom from service panel. To remove this panel (with the washer unplugged), take out the screws at the very bottom of the panel and then pull the panel down and out to remove it. Access to the motor control board may be limited. You may be able to check to make sure that wiring connections are firmly secured on the motor control board. If the connections are okay and you continue to get the F28 error code, you may need to replace the motor control board.
Nov 02, 2010 | Kenmore HE2 Plus Front Load Washer
Code set po335ckp senor.ck 3 pin con. corrosion both at pin con. and on sensor male pin in ckp sensor, replaced sensor clean pin con out with elect.cleaning solvent,check pin key on. three wire, yellow has...
insure timing belt is correctly installed and check cps trigger check continuity from cps sensor harness terminal 1 and pcm terminal A7 if all ok replace pcm with known good unit
Sep 21, 2010 | 2002 Honda Civic
Code fh is displayed
The FH code in the owners manual talks of a water supply . The F/H code means the unit isn’t detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I’ve seen this harness jiggle loose and cause problems. check figure for flowmeter location:-- ca83b83.jpg
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Whirlpool AWM8143 Front Load Washer
Possible wiring problem in dash
have had any codes pulled? i would do that first to see if it will give you a direction to head in. Otherwise you'll have to inspect the wiring harness to your combination meter and the combination meter ecu.
Jul 07, 2009 | 2003 Toyota Sequoia
Error code f h
The FH code in the owners manual talks of a water supply.The F/H code means the unit isn't detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems. check figure for flow-meter location. c3a1d6e.jpg
Or
May 10, 2009 | Whirlpool GHW9400 Duet Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
